Heater problem, please help
Old Dec 7, 2009 | 11:06 AM
Farino81's Avatar
Farino81
Default Heater problem, please help
I have already searched but ill explain my problem. i have a 94 sc400 and my heat only works at certain times. the heater control valve was just replaced less than 10k ago, but i noticed when i was warming up my car my radiator hoses werent getting hot, even when the car temperature was in the middle. The coolant level is fine, no coolant leaks, what could be causing this? both hoses were cold.
Old Dec 7, 2009 | 11:32 AM
Gspec's Avatar
Gspec
air pocket in the cooling system is the most likely culprit if the hoses are staying cold....air trapped by the thermostate can make it take forever to open...trying rebleeding the system, or having a shop with a vacuum filler refill your coolant.
Old Dec 7, 2009 | 11:34 AM
Farino81's Avatar
Farino81
i drained and refilled my coolant about 8 months ago and i put a funnel on my radiator and ran my car to get rid of the air bubbles but maybe i didnt get them all out. is there another way to bleed the system that i dont know about?
Old Dec 7, 2009 | 11:38 AM
LEX_MAN's Avatar
LEX_MAN
Did you raise the front of the car so that your radiator is at the highest point? If not then do it.
Old Dec 7, 2009 | 11:43 AM
Farino81's Avatar
Farino81
ya i had the car jacked up in the front, but i remember i did that and then about 4 months later i checked the resevoir and it was low so i added more coolant
Old Dec 7, 2009 | 04:40 PM
Farino81's Avatar
Farino81
i had to add more coolant and found alot of air in the system. whys there so much air in the system and is there any other way to get the bubbles out?
Old Dec 7, 2009 | 07:08 PM
LEX_MAN's Avatar
LEX_MAN
Did you have the heat on when you filled the rad ? Maybe some air was stuck in the heater core?
Old Dec 13, 2009 | 10:06 PM
MrFairlady's Avatar
MrFairlady
Heater Control Valave Dosen't Ness have to be replaced - You can Actually Reverse the Lines and Heat will work Fine....then just Reverse back ones Winters over to save some coin.
Sounds like proper Bleed is needed though,...or the Heater valve is Dead again.
HOPEFULLY you DIdn't pay for a Brand new $400 valve??
jasepb
Apr 11, 2019 03:07 PM
Cruisin101
Feb 2, 2018 01:16 PM
gmoney94
Feb 2, 2018 08:31 AM
johnnybmw1
Sep 20, 2010 02:14 PM
toy4life
Jun 2, 2010 07:24 PM
