Loud Start
Old Sep 28, 2005 | 07:17 PM
tbridgers's Avatar
tbridgers
Default Loud Start
My 1992 Lexus ES300 is very loud at the start and the noise seems like its coming from the front of my car. I think that my exhaust is cracked. My question am I right and what do I have to do and spend in order to fix the cracked exhaust?
Old Sep 29, 2005 | 06:47 AM
T0ked's Avatar
T0ked
describe the noise... need more info.
Old Sep 29, 2005 | 10:24 AM
tbridgers's Avatar
tbridgers
I am sure that the exhaust is cracked... the sound is not unusal it sounds like their nothing to muffle the sound and it is coming from the front end.
Old Sep 29, 2005 | 12:29 PM
meZoom!'s Avatar
meZoom!
Super Moderator
Get a friend to lightly rev the car while you stick your head in the engine. With a flashlight and some prying/prodding tools, check your manifold gasket. Don't touch with bare hands though unless you're certain it's cold.
Old Sep 29, 2005 | 12:49 PM
mkorsu's Avatar
mkorsu
Zombie Slayer
I would be more inclined to think exhaust LEAK before cracked exhaust.
Old Sep 30, 2005 | 07:12 AM
tbridgers's Avatar
tbridgers
Exhaust Leak????????
Old Sep 30, 2005 | 08:06 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
Yes. Exhaust leak! Like MeZoom said, possibly your exhaust manifold gasket. Could also be the connection between the exhaust manifold and the exhaust piping. Could be a host of other locations also. We're just suggesting this since an exhaust "crack" is not overly common. Rule out any leaks before you decide it's cracked. You may also want to really get in the engine and underneath it to fully inpsect the entire exhaust system.
Old Sep 30, 2005 | 01:09 PM
T0ked's Avatar
T0ked
By crack I think the manifold or piping has literally cracked open or one of the welds have come undone. A leak which is more common can be from the exhaust manifold gasket or any of the gaskets connecting the various piping together. Also, rust may have eaten away at the exhaust behind the heat shielding you see under the car.
Old Mar 16, 2006 | 08:30 AM
tbridgers's Avatar
tbridgers
Hey guys, its been a while. Anyway, I got my car fixed in Jan 06 and my exhaust pipe was eroded! It is a no longer loud and it just like the day I got it! I am in the process of changing the seals and gaskets. I'll be back with more updates.
bigeasy043
Aug 23, 2016 10:58 AM
justinp95
Feb 17, 2010 07:29 AM
Rock-a-Lex
Performance
Oct 24, 2007 08:01 AM
T-Lex
Jan 26, 2007 12:16 PM
RIGHTDNA
IS - 1st Gen (2001-2005)
Jun 5, 2003 09:22 PM
