changing negative wire, and door lock???
Old Sep 12, 2005 | 02:55 PM
soarer1023's Avatar
soarer1023
Default changing negative wire, and door lock???
hey everyone, just wondering how much around does a shop charge for changing the negative wire on the battery, my car got broken into last night, and the "A whole" cut my negative wire, so need to get that replace.
same thing with my driver side door, the "A whole" damaged the door lock, just how much is that to get that repair or replace.
Old Sep 12, 2005 | 03:37 PM
Dx3's Avatar
Dx3
You can replace your neg- battery cable in about 10 minutes yourself - don't waste money paying someone else to do it.
Jonny
Old Sep 12, 2005 | 06:06 PM
rgarjr's Avatar
rgarjr
Sounds like he cut the negative wire on the battery to cut off the OEM alarm system. If you're talking about the outside keyhole door lock, you probably have to get a new one.
Old Sep 12, 2005 | 07:38 PM
soarer1023's Avatar
soarer1023
yeah i m talking about the outside keyhole, and if that's the case, i m pretty sure that i have to bring it to a lexus dealer right, will toyota dealer work??
Old Sep 13, 2005 | 11:06 AM
meZoom!'s Avatar
meZoom!
Super Moderator
The amount will generally depend on how much damage there is. Did they totally remove the particular lock and is that cylinder gone? Or is it still "somewhere"? Were they "nice" A-holes and cleanly snipped off a little end of the negative terminal (probably not) wire so there's enough length to just put on a new terminal? Or in their hurried attempt did they just cut the crap out of it at some random place?
Old Sep 13, 2005 | 11:22 AM
soarer1023's Avatar
soarer1023
what i think they did was like rgarjr said that person cut the wire to cut the OEM alarm off while working on the car, but couldn't take out the head unit so just took my CDs and the battery, and i already got the battery terminal fix.
and the lock, somehow, that person used something to create a whole right next to the keyhole and got in from there. my key can still turn to unlock the car, but it does send the signal to the computer to dis-arm the alarm so i can't fire up the car. so now inorder for me to drive, i have to unlock the car from the passager side, so that i can drive the car. any advice and help on that will be very appreciate. thx
KingLS
Sep 24, 2017 07:02 PM
mwwilliams
Jun 25, 2017 11:40 PM
tarekium
RX - 1st Gen (1999-2003)
Jan 10, 2009 08:09 AM
qwert26
Aug 8, 2001 02:28 PM
