Engine pinging
Old Sep 4, 2005 | 09:47 AM
dry-fly's Avatar
dry-fly
Default Engine pinging
I've got a 90' LS400 with around 180k on it that has been pinging for some time. It does it almost exsclusively under light acceleration. Se***s to be worse in the summer with the AC on. I've tried lot's of fuel treatments, put in a new air filter, no engine codes, I use premium gas. Any ideas?? Thanks.
Old Sep 4, 2005 | 10:22 AM
Lexusfreak's Avatar
Lexusfreak
Cool
I perform a 'major' tune up with top quality brand name parts to start with & have the injectors professionally flushed. Use NGK or Denso spark plugs.
Old Sep 4, 2005 | 11:08 AM
HarrierAWD's Avatar
HarrierAWD
A common cause of engine pinging is carbon deposit. Many top brand gas treatment like Techron or STP claim to remove it. From my own personal experience with my last car, only the Berryman Chemtool B-12 worked. You can find it at AutoZone. Just one bottle will do.
Old Sep 4, 2005 | 12:09 PM
dry-fly's Avatar
dry-fly
I've tried Berryman's, Seafoam, Redline, Techron......some of them more than once..
Old Sep 6, 2005 | 07:11 PM
dry-fly's Avatar
dry-fly
No more ideas?
Old Sep 7, 2005 | 03:57 AM
T0ked's Avatar
T0ked
Have you checked your timing?
Old Sep 7, 2005 | 02:18 PM
dry-fly's Avatar
dry-fly
No, that's one thing I could do.........
Old Sep 7, 2005 | 09:42 PM
T0ked's Avatar
T0ked
Pinging means detonation usually. Common causes are carbon deposits as mentioned already, but also faulty fuel pump/filter, timing. Pull your plugs and see if they are black (normal depending on how old they are), or have a sheen of silver on them (bad). That will show you how serious the problem is. Full tune up is in order.
iceblast
14
May 20, 2013 09:39 AM
nilambari
Maintenance
Jul 10, 2010 10:44 AM
sexilexi
Maintenance
Aug 9, 2005 05:57 PM
