Need help! Squealing From Under Car
Old Aug 17, 2004 | 06:10 PM
Pinball's Avatar
Pinball
Angry Need help! Squealing From Under Car
Fellow Forum people, your help is desperately needed! My 2000 SC400 has developed a transitory, intermittant squealing noise in what sounds like the underside of the front portion of the car, near the front wheels. The noise sounds like a squeeky hamster wheel, not too loud but persistent and clearly audible when it shows up. When I've taken it to the dealer, I can't duplicate it for the tech. This is driving me nuts. It seems to happen mostly between 15-35 mph; mostly at the end of the driving day; mostly on smooth roadway on a gentle up or down grade. At first I thought the front end just needed a lubrication, but the service manager assured me that this wasn't the case. I drove him around for 15 minutes, and (of course) the noise didn't pop up. Arrgh! Has anyone experienced this before? Any ideas? Bad bearings? Bad shocks? Any ideas and possible fixes will be gratefully received! Thanks! Paul
Old Aug 17, 2004 | 10:16 PM
tpham7's Avatar
tpham7
same problem on my sc300...it annoys the crap out of me...sometime it shows up and sometime it doesn't.
I think mine is coming from the brakes because everytime I brake the noise goes away and when I release the pedal it comes back.
Old Aug 18, 2004 | 12:10 AM
legendary's Avatar
legendary
is this in the very beginning of driving cycle?
Could be cold brakes...
Need more info
Miles
Last Service
Last brake service
....To name a few
Old Aug 18, 2004 | 01:13 AM
JamesN's Avatar
JamesN
Check the brake and the 2 caliper pin. it might need some grease. good luck
Old Aug 18, 2004 | 03:24 AM
jeremyp111's Avatar
jeremyp111
Yep, this is most likely the cause. The pins sometimes get stuck or don't move as freely as they should. Also could be the pads are worn out.
Old Aug 18, 2004 | 04:57 AM
Pinball's Avatar
Pinball
Default Squeaking and squeeling
It usually comes on closer to the end of the driving day rather than the beginning. It's always associated with acceleration under low throttle; it does not appear under braking. Does this change your diagnosis?
Old Aug 18, 2004 | 04:59 AM
Pinball's Avatar
Pinball
Default Ooops...Sorry...Forgot
The miles are 28,000. Last service was 3k ago. Always serviced religiously.
Old Aug 25, 2004 | 06:30 AM
B1TEM3's Avatar
B1TEM3
Check the sway bar bushing. i had that squeky noise when the road goes up and down. i removed my rubber bushing that hold the sway bar and put anti freeze lub on it.
Old Aug 25, 2004 | 01:26 PM
Pinball's Avatar
Pinball
B1TEM3, did that lube solve the problem? I did all the brake work last week at my local dealer, including new brake pads and lubing the caliper pins, but the problem is still there. How did you figure out what it was?
Old Apr 10, 2005 | 04:29 PM
spyder357's Avatar
spyder357
Question
Did the grease solve your problem? I have the same noise, it sounds like a squeaky hamster wheel but if I lightly press the brakes it goes away. Very annoying.
Old Apr 10, 2005 | 06:09 PM
Pinball's Avatar
Pinball
Spyder - Yes! The problem was solved, and 10K later, no more hamster wheel noise!
Old Apr 10, 2005 | 10:12 PM
spyder357's Avatar
spyder357
Thanks, I'm gonna give that fix a shot, this noise is driving me nuckin futz!
Old Jul 16, 2006 | 01:11 AM
B1TEM3's Avatar
B1TEM3
Glad to help
Old Jul 16, 2006 | 08:53 AM
Tammy's Avatar
Tammy
Drown the sway bar rubber bushings (4) with Areospace 303 or Vinylex. Work it into the pivit point body mounts and the bar end bushings. If needed, remove both end mountings to swivel the bar on the mounts.
Many types of grease may break down the rubber in the bushing. Rubber preservatives or protectant may be a better choice.
Fpan87
RX - 3rd Gen (2010-2015)
23
Jun 7, 2024 06:44 AM
CaltonB
RX - 1st Gen (1999-2003)
Sep 23, 2017 01:41 AM
bonson
Oct 25, 2011 08:11 AM
koojstar
Jan 30, 2010 10:58 PM
chuckisc
Feb 25, 2003 06:01 AM
