Spark plugs for first gen gs300??
Old Jun 28, 2004 | 08:55 AM
johnee78's Avatar
johnee78
Default Spark plugs for first gen gs300??
What kind of spark plugs can be used for the first gen gs300?? Can the plugs for a second gen work???
Old Jun 28, 2004 | 03:47 PM
VVT-i's Avatar
VVT-i
You have to look at the number on the spark plug itself. The heat range or gap may be difference even know both plugs are platinum.
Old Jun 28, 2004 | 05:45 PM
saber's Avatar
saber
Look in your owners manual index under "engine specifications" . Turn to the "engine specifications" page and there it will tell you exactly what Nippondenso or NGK spark plugs to use.
Old Jun 28, 2004 | 07:47 PM
lexusk8's Avatar
lexusk8
Try out this link for all your spark plug needs: http://www.sparkplugs.com
Old Jul 6, 2004 | 11:10 AM
johnee78's Avatar
johnee78
Exclamation
I cross referenced the spark plugs and the denso iridium plugs for my my gs are IK16..Can anybody verify this please??Is there an advantage to using these plugs???
Old Jul 6, 2004 | 09:29 PM
johnee78's Avatar
johnee78
Question
Old Jul 8, 2004 | 06:37 AM
johnee78's Avatar
johnee78
Question
can someone verify the plug number???
Old Jul 8, 2004 | 10:08 AM
lexusk8's Avatar
lexusk8
johnee, you're correct; the Denso plug part # for your '93 GS is IK16. Here's the page listing all available spark plugs for your car:
http://www.sparkplugs.com/results_ap...1&AAIA=1187401
Old Jul 8, 2004 | 10:43 AM
LB Lex's Avatar
LB Lex
Thanks for the links Lexusk8 I've been reading through the Spark Plug 411 section and it states that iridium plugs last longer and allow the manufacturer to use a very fine (thin) electrode so it takes less voltage to jump the gap, which in turn helps with power and gives fewer misfires. It also said that Denso iridiums have an electrode size of 0.4mm and the NGK iridiums are 0.7mm (regular plugs are 2.0-2.5mm). Since there is around a $25 difference between a set of Denso Iridiums and NGK iridiums, it's really no big deal to get the best.
My question is, does the difference of .3mm between the Denso and NGK make much of a difference?
Old Jul 8, 2004 | 11:03 AM
johnee78's Avatar
johnee78
Thanks, that site is where I got my info to begin with.I just wanted to be sure before I ordered...Thanks again..
is3504bao
Sep 23, 2022 11:01 AM
Methodical
SC400 / 300 Classifieds
Jun 6, 2009 02:16 PM
GS3.0
Jul 9, 2008 07:59 AM
ShowGSLuVv
May 11, 2002 12:42 PM
