wheel alignment
Old Jun 10, 2004 | 05:51 PM
bishop977's Avatar
bishop977
Default wheel alignment
i just got new tires in and a alignment with it. when i left i noticed that when i hold the steering wheel straight it fades to the left a little. i got warranty on my alignment. i'm planning to bring it back to get it fix. i found alignment spec on spec not sure which one i should follow for my 92 sc300. should i follow these specs? or let the tech do it?
i'm looking at the print out of my alignment they didn't have ne thing for the front caster and doesn't show a thing for the king pin degree that they talk about on the website??
since i don't have access to a scanner i'll type out my results
left front 0.1 camber right front -0.0
left ront 0.09 toe right ront -0.00
Front
cross camber 0.1
total toe 0.09
left rear -1.4 camber right rear -1.5
left rear 0.18 toe right rear 0.14
Rear
total toe 0.32
thrust angle 0.02
Old Jun 15, 2004 | 10:16 AM
VSsc400's Avatar
VSsc400
i think alignment shops on the alignment machines they have the specs on the computer. They will adjust to bring it back to factory settings. I say leave it to the techs... best bet is to go with Hunter wheel alignment machines. They are supposed to be the best. Other than that i found sears do a good job with wheel alignment.
nandob
Suspension and Brakes
Feb 21, 2014 05:29 PM
qgoat
Mar 18, 2010 04:19 PM
MarcusMIA
Oct 14, 2009 07:08 PM
vwynn
Jun 5, 2009 05:03 PM
aspguru
Mar 5, 2006 12:09 PM
