Gl-5
Old Jun 16, 2004 | 12:36 AM
autodriver's Avatar
autodriver
Default Gl-5
My User's Manual suggest to use GL-5 Gear Oil for the differential.
- 80W if operate below 0 degree
- 90W if operate above 0 degree
Can I use Valvoline DuraBlend 85W-140?
Old Jun 16, 2004 | 06:47 AM
XYZLexus1's Avatar
XYZLexus1
no, It would be to "heavy" of a lubricant. I know castrol and valvoline make 80W90 and Mobil 1 makes 75W90. 85w140 means 85W when cold or winter, and 140 for when it is hot. The larger the viscosity range the less lubricant in the same volume of lubricant. To make it go from 85 to 140 additives are in the oil, these addiditives do not add any lubricating properties. A single weight oil such as 80w or 90W will be superior because it is nothing but oil. Imagine a ball of spagetti. when it is cold the ball is bunched up, whe it gets warm in spreads out making the oil thicker that is how I understand additives work.
jrk1956
Jun 4, 2019 05:32 AM
gandro
Maintenance
Jan 9, 2010 08:36 AM
Zeal3
Apr 19, 2009 04:07 PM
818sc400
Maintenance
13
Mar 27, 2009 07:52 AM
sleepybobcat
RX - 1st Gen (1999-2003)
Feb 28, 2002 01:43 PM
