Ignition greasing/lighting/cover replacement ?
Old May 10, 2004 | 10:40 AM
siniquezu's Avatar
siniquezu
Default Ignition greasing/lighting/cover replacement ?
I've got a couple of ignition key questions.
1) Should I grease the ignition key slot? What about the door locks? If so, should I use WD40 or white lithium grease?
2) How do I change the green light on the ignition key slot?
3) The ignition slot cover that's labeled with the ON/START/etc. keeps falling off. I try and twist it in and it still won't stay. I'm thinking of replacing it because it's scratched up. If I replace it, what is the part number and does it stay on?
Thanks guys.
Old May 10, 2004 | 10:42 AM
mikeloc24's Avatar
mikeloc24
Lexus of Westminster #714.892.6906
DrMikeinPD
Apr 4, 2019 06:09 PM
cp73
RX - 4th Gen (2016-2022)
Apr 25, 2016 12:12 PM
skibear99
Sep 21, 2014 06:18 AM
vdn20
Apr 24, 2014 10:35 AM
Wisdom
Mar 17, 2014 10:20 PM
