Brakes - 96LS
Old Mar 30, 2004 | 09:17 AM
NiteOwl's Avatar
NiteOwl
Default Brakes - 96LS
Getting ready to do brakes on my 96LS400. Going to replace the rotors with Brembo and get ceramic pads, both likely from Tirerack ($75 per rotor/$50 for the pads) - unless someone has a cheaper alternative. The damn brake sensor is like $100 from the local dealer - can't find anyone in the aftermarket online that can get it. Any suggestions? Cheaper online Lexus parts dealer? Thanks in advance...
Old Mar 31, 2004 | 12:54 PM
Rice's Avatar
Rice
That sounds like a good deal.
I'm not sure if ceramic pads will benefit you in any way, unless you are planning to rase.
You can reuse your sensors unless they are broken.
Old Mar 31, 2004 | 01:19 PM
RA40's Avatar
RA40
Super Moderator
I was under the impression that the stock pads on the LS were a ceramic composite material?
Old Apr 3, 2004 | 01:57 PM
SharpLS-96's Avatar
SharpLS-96
They are a ceramic composite.
Also, as Rice stated you can reuse the brake sensor. Just don't damage the sensor when you disconnect it from the calibers when your removing your old pads.
deeken
GX - 1st Gen (2003-2009)
Jul 14, 2018 05:35 AM
lex460l
Sep 2, 2013 09:26 AM
Bigrahizzl
Suspension and Brakes
Aug 26, 2010 04:11 AM
Ned
Oct 9, 2003 01:03 AM
JYOO
Maintenance
Sep 30, 2002 09:33 PM
