LX - 4th Gen (2022-present) Posts related to the LX600 belong in this forum
Disabling auto Stop Start
Old Nov 9, 2024 | 08:39 PM
  #76
LX600F's Avatar
LX600F
2nd gear
I just received today as well. Works great.
One thing I noticed is it appears to only work when you start the car cold. I installed the device, started the car and the light appeared. Then, I drove to a parking lot, and turned the engine off while staying in the seat. When I restarted the engine, the light did not appear, but when coming to a stop the dashboard said battery charging so I believe the start stop feature would have come on later.
I tried again and left the car and locked it, walked away, came back and started car and the light appeared again. Side note: it’s cool how at night when you approach the car locked it welcomes you with puddle lights with Lexus logo. Also make sure when reinstalling the side cover to pull the weather stripping outside the panel again.
Overall, it suits my needs and helps if someone else is borrowing it for them not to deal with finding the button.
Old Nov 10, 2024 | 05:07 AM
  #77
gerryvz's Avatar
gerryvz
interesting …..
I have not noticed the feature only working on cold starts. It has worked 100% of the time on cold or hot starts for me, as long as I have not pushed the Circle-A button on the dash.
Old Nov 13, 2024 | 07:20 PM
  #78
HarkinBank's Avatar
HarkinBank
Originally Posted by HarkinBank
Ordered.
I’ll update when received and installed.
HB
Just put 500 miles on LX with the dongle. Auto start/stop is disabled and no issues.
HB
Old Nov 14, 2024 | 04:52 AM
  #79
sean950054's Avatar
sean950054
10th Gear
My fear of installing anything like this is of or when something happens under warranty that might involve electronics..Lexus could come back and say you modified the vehicle and not cover the repair under warranty.
Old Nov 14, 2024 | 08:28 AM
  #80
gerryvz's Avatar
gerryvz
This plug-in is easily removable in under 5 minutes.
What are you thinking the “something” (problem?) is that would happen? All this device is, is something that mimics the pushing of the circle-A button on the dashboard — an established function of the vehicle — and simply stores and preserves the “off” electrical signal between start-ups of the engine, instead of requiring one to manually push the button.
So, I am just not seeing what could go wrong or what problem could crop up that would require a warranty repair.
And …. if a repair WAS required for some reason, how would Lexus even know that this device was ever even installed?
Old Nov 14, 2024 | 08:30 AM
  #81
gerryvz's Avatar
gerryvz
HB
thanks for the update. Glad for the additional confirmation that the device is working as it should.
Old Nov 15, 2024 | 01:15 PM
  #82
3ZERO8's Avatar
3ZERO8
Got mine today so Installation hopefully tomorrow, I’ll update.
Old Nov 16, 2024 | 09:18 AM
  #83
3ZERO8's Avatar
3ZERO8
Auto start stop dongle has been installed and works as expected.
Old Nov 17, 2024 | 02:18 AM
  #84
motin's Avatar
motin
Default Driving with it nonstop with no faults whatsoever
in any case and in any fault you could always take it off in less than two minutes it does not leave any trace
Old Nov 23, 2024 | 05:13 AM
  #85
3ZERO8's Avatar
3ZERO8
Has anyone tried to remote start the LX after installation of the gizmo? I auto started mine last night at home, got in the truck (it shuts off after unlocking it) and when I restarted it, the auto started stop gizmo wasn’t working. After I got to where I was going and shut the truck off, it was sitting for a couple of hours, I restarted the truck and the gizmo was working again. Anyone test this yet?
Old Nov 24, 2024 | 08:17 AM
  #86
gerryvz's Avatar
gerryvz
Interesting.
I will check that out today.
Old Nov 28, 2024 | 06:15 AM
  #87
3ZERO8's Avatar
3ZERO8
BUMP….Nobdy has tried this yet?
Old Dec 2, 2024 | 06:24 AM
  #88
gerryvz's Avatar
gerryvz
(redundant post, mod please remove as I cannot delete).
Old Dec 2, 2024 | 06:25 AM
  #89
gerryvz's Avatar
gerryvz
Originally Posted by gerryvz
Interesting.
YES, the start-stop ("circle-A") functionality is NOT PRESENT when the LX is remote-started (and as said, shuts off when the truck is unlocked, and then re-started to go wherever one is going).
I parked and locked the truck for 5-10 minutes to run inside a store for an errand. When I came back out (didn't remote-start this time), when I started the truck the start-stop suppression function was ENABLED again.
So, it seems, that when the truck is remote-started, the start-stop removal function goes away. When the truck is started with the key fob in proximity, the functionality is enabled.
Thanks for seeing and flagging this quirk, @3ZERO8!
Old Jan 3, 2025 | 08:37 PM
  #90
4les's Avatar
4les
Does this only require the side of the dash to be removed or also the front?
