LX - 4th Gen (2022-present) Posts related to the LX600 belong in this forum
Mileage range issue
Old Oct 3, 2023 | 08:30 PM
tiger44's Avatar
tiger44
1st Gear
Default Mileage range issue
My new lx 600 when filled with full tank shows a range of 276!
Published range is 358 in city. What is going on here? Lexus keeps telling me this will correct itself after more miles on the car!
Old Oct 4, 2023 | 05:31 AM
Flying3's Avatar
Flying3
https://www.clublexus.com/forums/lx-...-of-lx600.html
Old Oct 4, 2023 | 06:29 AM
BillUK's Avatar
BillUK
Published range is based on a set of ideal test condiitions, whereas the range on your computer is based on your specific ciircumstances. Range will be affected by how and where you drive, as well as brand and grade of fuel used, and the computer will make its calculations based on how much fuel is actuallly used over how many miles actually driven. The longer you drive, the more it learns, and the more accurate it will become.
Old Oct 4, 2023 | 04:43 PM
SC3coupe's Avatar
SC3coupe
358 in city? good luck trying to get that
Old Oct 5, 2023 | 05:50 AM
Flying3's Avatar
Flying3
Agreed. That's about the range I am getting with 95% highway.
Old Feb 9, 2024 | 10:26 AM
PoolMan0715's Avatar
PoolMan0715
1st Gear
Default 330 Miles Max
[QUOTE=tiger44;11589619]My new lx 600 when filled with full tank shows a range of 276!
I just ran out of gas after getting 330 mile from a full tank. Refilled it and it only took 19.3 gallons. This is a real problem!
Old Feb 9, 2024 | 07:28 PM
BayeauxLex's Avatar
BayeauxLex
[QUOTE=PoolMan0715;11666117]
Quick google shows you have a 21.1 gallon tank. Did you try pumping more after the 1st click on the pump? I would think you should’ve been able to pump more than 19.3 gallons.
Old Feb 9, 2024 | 07:53 PM
NickL's Avatar
NickL
You drove until the engine sputter and it only takes 19.3? Or the fuel warning light comes on?
Here’s a 3gallons or so reserve Lexus program for the low fuel light to come on.
Also, I wouldn’t try to pump more fuel after the trigger has clicked. You might cause damage to the vapor line.
Old Feb 12, 2024 | 07:21 AM
z32's Avatar
z32
Yes, like the OP said... when the gas nozzle clicks, do not try to fuel more as there are EVAP lines somewhere along the refill neck that needs 'to air out' (I think to the canister)...so if you pump more gas once the gun clicks, it may over filled will eventually damage EVAP - CEL will alert you too - fail smog? Also do not let the gas run so long before refuel, as the fuel pump uses gas to cool down so if the gas run so low the pump will run too hot and will shorten its life.
Old Feb 12, 2024 | 07:40 PM
Jcrame00's Avatar
Jcrame00
3rd Gear
Has anyone experimented with an extended-range fuel tank for the LX 600, or is such an option available?
jindo24
Hybrid Technology
87
Aug 29, 2022 03:35 AM
il107
Oct 14, 2021 01:24 AM
bwhitaker
48
Dec 19, 2019 03:21 PM
cnplkart
Hybrid Technology
Nov 24, 2015 06:34 PM
JASP615
GX - 1st Gen (2003-2009)
27
Apr 20, 2007 11:31 AM
