LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
Red Fluid Leak
Old Jan 1, 2024 | 09:19 AM
Matthewtj8's Avatar
Matthewtj8
5th Gear
Default Red Fluid Leak
I’m having an issue with red fluid on my garage floor, not a ton of fluid but a little bit is enough. The fluid has no smell and is oily so I’m thinking hydraulic fluid. Has anyone else here had an issue with a hydraulic leak, it seems to be about midway of the vehicle in the middle. It’s on a 2013 LX570 w/ 149k miles
thanks in advance
Old Jan 1, 2024 | 11:08 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Please get under the truck and take a look…could be ATF or the hydraulic suspension
Old Jan 1, 2024 | 03:04 PM
Matthewtj8's Avatar
Matthewtj8
5th Gear
Default Fluid
I have looked and looked and can not trace the leak, not sure where it’s coming from unfortunately, I’m a plumber and normally pretty good at finding leaks but I get right where the small puddle is and see nothing above
Old Jan 1, 2024 | 03:19 PM
Capture some of the liquid and add water you'll know right way if it's coolant or ATF.
Old Jan 2, 2024 | 05:59 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
can you take some pictures of the fluid and the underside of the truck where you think it is coming from.
does it seem to be a cold engine leak or when it is hot, or can’t tell?
how is the anti freeze level?
Old Jan 2, 2024 | 06:04 AM
KennyFSU's Avatar
KennyFSU
If it smells sweet, coolant.
If it smells awful, ATF.
Old Jan 2, 2024 | 10:04 AM
mfeferman's Avatar
mfeferman
Default Probably leaking valley plate
Is your radiator overflow tank low? Do you find that you have to fill it occasionally? If so and your truck is pre-19, then I’m guessing leaking valley plate.
hugo2648
Nov 1, 2024 02:08 PM
cwolaw
Jun 2, 2014 08:53 PM
sojah
Nov 22, 2010 03:22 PM
ToyotaLexus
RX - 1st Gen (1999-2003)
Feb 26, 2009 07:33 AM
