LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
LX570 Cell Phone Mount (merged threads)
Old Jul 14, 2023 | 11:45 AM
  #31
RavenRemix's Avatar
RavenRemix
I used these Anker Powerwave MagSafe chargers mounted to the air conditioning vents. I used one of the mounting solutions in the box from Anker, and the other was bought from AliExpress that has a little hook that goes behind the vent. I ran flat braided USB-C cables under the dash and behind the trim to under the steering wheel where I have a 2-USB adapter wired into an always-on fuse with one of those add-a-fuse wires.
Not 100% clean but clean enough that I don't see any of the infrastructure. You can replace the MagSafe plates with any other holder to support Android phones or stick a metal ring onto your Android phone case.
Works better than the factory Wireless Charger as I can put something bigger on them
It does slightly block the "tune" **** or if you have a BUCC-EES extra large cup in the cupholder.
I put two in, one for the better half.
I barely use the factory wireless charger I specially installed. I think with MagSafe cases it stops charging because it detects metal. I was told this is an issue on the LX600 as well.
Old Jul 15, 2023 | 07:02 AM
  #32
rkitchennc's Avatar
rkitchennc
8th Gear
I recommend the Weathertech phone holder. Easy to use and effective.
Old Jul 15, 2023 | 07:06 AM
  #33
Bgw70's Avatar
Bgw70
Veteran: Air Force
how does it mount?
do you have a pic or a link?
Old Jul 15, 2023 | 08:44 AM
  #34
rkitchennc's Avatar
rkitchennc
8th Gear
Default LX 570 Cell Phone Mount
The Weathertech holder is simply installed into a cup holder. See attached photo.
File Type: pdf
Old Jul 15, 2023 | 11:16 AM
  #35
hankinid's Avatar
hankinid
Originally Posted by Bgw70
how does it mount?
It sits in the Lexus cup holder.
How 'bout weathertech.com???
Old Jul 15, 2023 | 07:20 PM
  #36
Bgw70's Avatar
Bgw70
Veteran: Air Force
thanks, never heard of a weather tech, 😉 😂
Old Jul 15, 2023 | 07:21 PM
  #37
Bgw70's Avatar
Bgw70
Veteran: Air Force
thank you…
Old Jul 16, 2023 | 04:45 AM
  #38
FBH's Avatar
FBH
I have the same Pro Clip (left sided It works great!
Old Aug 9, 2023 | 08:53 AM
  #39
baktasht's Avatar
baktasht
After I got the carplay retrofit installed I had no need to mount the phone in a visible fashion. I ended up ordering the saddle storage units from aliexpress to have a place to put my phone and other things. Have been super happy with them.
- here's the storage saddles. They are actually much better than I expected:
- here's the carplay retrofit
Old Aug 10, 2023 | 08:47 AM
  #40
islandbeef's Avatar
islandbeef
This is mounted on the left air vent and it works great!
https://www.amazon.com/gp/product/B09XMFXPDM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B09XMFXPDM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
johnllx
RX - 5th Gen (2023-present)
May 27, 2023 02:38 AM
bbmach
Dec 18, 2022 06:32 AM
prthompson
CT 200h Model (2011-2017)
Nov 6, 2019 02:29 PM
Craigyyy
GX - 2nd Gen (2010-2023)
17
Aug 11, 2016 12:43 PM
JL6speed
Jan 6, 2011 02:56 PM
