need help on cd error code on LX450
i got 97 lx 450...and just got an error code "err 22"...cd seems to be ejected fine...when I loaded..sounds like it's loading fine...then when i changed the cd (from 1-6) from the HU..sounds like it's working..but when it's finally load a particular cd...it doesn't bring any track...and finally display "err 22"...
help..what can I do with this...thanks a lot guys..
Did you put the label side up or down?
The label is supposed to be facing down when you put in a cd.
This should hopefully fix the problem.
______________________________
96 Lexus LX 450
97 Land Cruiser 40th Anniversary
96 Lexus LX 450
For what it's worth, my service advisor has told me that if you put a label on a CDRW that it can sometimes not play, but reguar cd's are no problem. If it's a CDRW, possibly try not using a label.
speedracer
Oct 11, 2004 05:45 PM
