My GX does not Eject the CDs out
Old Mar 14, 2010 | 09:58 AM
mann777's Avatar
mann777
Default My GX does not Eject the CDs out
Is there anything I should do have the CD throw out, I get an code
"CD ERROR 3".
Is there anybody else had the similar issues, I have gone through posts posted on here, but no solutions.
Old Mar 14, 2010 | 11:48 AM
aljodoro's Avatar
aljodoro
Default error 3
I googled cd error 3. In one of the posts here from toyotanation here is what I found:
In Scion's, Error 3 typically means it can't read the disc or the unit has failed. Take it in and get it replaced. Description of errors for Scion CD players:
ERROR CODE DESCRIPTIONS:
�� Error 1: Dirty Disc/Cannot Read Disc (Clean CD as needed and try again.)
�� Error 3: Mechanical Malfunction (Replace CD player.)
�� Error 4: CD Player Overcurrent (Allow CD player to cool and try again.)
posting reference: http://www.toyotanation.com/forum/sh...d.php?t=260757
Here's another one which points to the problems and liittle solution other than replacment.
http://www.toyotanation.com/forum/sh...d.php?t=226483
Interesting but it seems this is a common issue. Some people have taken the unit apart. Here is a posing on an audi. Seems to sum it up.
Hi saw no "reset" type button on the back.
Well,
I decided that paying Audi £300 wasn't an option, so, I stripped the unit down!!!
I did this WITHOUT breaking the seal!!!
I took the front end completely off, released the CD magazine, pulled it out from the head unit which then enabled me to look directly at the CD's in the unit.
I could see that they were not all in-line so with a very small screw driver I simply pushed the edges of the CD's together which in-turn snapped them back into place!
I'm not sure how I would have got the CD's out if I had needed to, but thankfully it was not needed!
So, the unit went back together, back in the car and hay presto. it works fine!!!!
I hope others read this as I'm sure there are many prople who just shell out the money!
I must point out though, it is not a job for the "Heavy Handed"
there are repair services on ebay. I would take it out and try to see if I could get to the cd's.
google - CD Error 3.
Old Mar 14, 2010 | 06:03 PM
mansito's Avatar
mansito
Wished I could help you, but we've never used the CD changer on our GX. Mostly use the iPod via cassette adapter. There should be a way to manually eject the CDs.
Old Mar 14, 2010 | 09:11 PM
mann777's Avatar
mann777
Thanks Mansito I think I may have to split open out the system to check out if the magazine is having a problem, if it so, then i may order one. New one cost 55 bucks only. It is better than replacing the whole stuff. As you have quoted from the toyota nation, code three refers to Mechanical, then for sure this is the magazine tray problem.Any I will let you know once i get this job done.
Old Mar 17, 2010 | 07:41 AM
sphy1005's Avatar
sphy1005
I have a code error 4. I just searched google and over at lexusowners club it says you can reset if by
1. Turn off cd player
2. Turn off car
3. Hold power button on Cd player
4. Turn on car.
Not sure but I'm gonna try that on my car at lunch
Old Mar 23, 2010 | 02:02 PM
jsmithkra's Avatar
jsmithkra
Default cd will not eject
I have an 04 also and had the same problem. Lexus replaced the entire unit. It may have been past the warranty but I am not sure.
Old Oct 8, 2011 | 06:21 PM
tangcov's Avatar
tangcov
10th Gear
2. Turn off car
4. Turn on car.
Does this work on GX470 2003? I tried the procedure but it did not clear out my error 4. How long do I need to hold down the power button of the radio after I turn the car on.
shift2win
Apr 29, 2013 02:34 PM
igorxx
Jul 25, 2010 08:54 AM
Mobulus1
Jul 6, 2009 07:07 PM
speedracer
Oct 11, 2004 05:45 PM
