30k miles service package
Old Sep 13, 2025 | 05:41 PM
22LS500's Avatar
22LS500
10th Gear
Default 30k miles service package
Hi everyone!
I have a 2022 with a little over 32k miles. My dashboard says "Maintenance Required". I just booked an appointment with a Lexus dealer and it will cost me almost $1000 for this 30k miles service package. Is it worth it? I also have extended warranty.
Old Sep 13, 2025 | 06:15 PM
PGA71's Avatar
PGA71
Here is what 30K mile service calls for:
FACTORY RECOMMENDED SERVICE FOR 30K MILES / 36 MONTHS
  • Replace Engine Oil And Oil Filter (Reset "Maint Reqd" Light If Equipped after maintenance at every 5,000 miles.)
  • Rotate Tires (Applies to models with same size front and rear tires and wheels.)
  • Check Installation Of Driver's Floor Mat
  • Inspect Ball Joints And Dust Covers
  • Inspect Brake Lines And Hoses
  • Inspect Rear Differential Oil
  • Inspect Engine Coolant (Refer to ""Engine Coolant"" in the ""Explanation of Maintenance Items"" section of the Warranty and Maintenance Guide for more information.)
  • Inspect Steering Linkage And Boots
  • Replace Engine Air Filter
  • Inspect Exhaust Pipes And Mountings
  • Replace Cabin Air Filter (If Equipped)
  • Inspect Fuel Lines And Connections, Fuel Tank Band And Fuel Tank Vapor Vent System Hoses
  • Inspect Fuel Tank Cap Gasket
  • Reset Oil Maintenance Reminder, if Oil was Changed
  • Replace Brake Fluid
  • Replace Smart Key Battery
  • Inspect Axle Shaft Boots
  • Inspect Transmission for Signs of Leakage
  • Inspect Body/Chassis
  • Inspect Variable Gear Ratio Steering Assembly, if Equipped
  • Inspect Wiper Blades
  • Visually Inspect Brake Pads, Calipers and Rotors
  • Reset Scheduled Maintenance Reminder
  • Measure Thickness of Brake Pads and Rotors (with F SPORT Package)
  • Inspect Rack-and-Pinion Assembly
  • Inspect Transmission Fluid Cooler Hoses and Connections
  • Add Toyota EFI Tank Additive or equivalent(For island use only) (Hawaii only)
  • Measure Brake Pad Thickness, Rotor Thickness And Runout
  • Perform Road-Test on Vehicle
Old Sep 13, 2025 | 06:57 PM
22LS500's Avatar
22LS500
10th Gear
Have you ever gotten this service done at a Lexus dealership?
Old Sep 13, 2025 | 08:23 PM
liazon's Avatar
liazon
you've probably figured out since posting the maint. required light likely refers to a 5k interval for an oil change and can be reset by you. just google the procedure. it's the same on most (all?) toyota products.
that said, having owned lexus for over 25 years now, absolutely do all scheduled maintenance including the recommended inspections. it's always been a key component of the brand's great reliability.
finding a local toyo specialist you find to be trustworthy is always recommended. many of them were previously dealership techs who opened their own shops. until then, yes the dealership charges a premium but also comes with the piece of mind of dealing with people who are knowledgeable and professional
Old Sep 15, 2025 | 07:36 AM
mbarron37's Avatar
mbarron37
There is a lot of “inspect”, not enough replace. A little rich IMO. I generally only get oil changes at the dealer and only when there is a special or coupon.
I’m cheap 😂😂😂
Old Sep 15, 2025 | 08:30 AM
Bigoofy's Avatar
Bigoofy
You wonder if they even remove all of the engine compartment cladding. It's pure profit for the dealership.
Old Sep 16, 2025 | 06:10 AM
sajack's Avatar
sajack
Default Video
I have heard of dealers that do an inspection video for the owner. Seems sort of silly, but would be better than nothing.
Replacing brake fluid is a big one. I have owned over 40 vehicles and only remember doing this on 2 of them. Seems like a ridiculous thing to do at 30,000 miles.
Old Sep 18, 2025 | 11:07 AM
Superbock's Avatar
Superbock
I didn’t do my 06 GS300 brake fluid replacement during coverage and didn’t have paperwork that I did. Down the road my rear calipers were starting to freeze because of a known issue with the slide pins. A mechanical issue but was refused because of it. I call corporate but they didn’t cover it.
Old Sep 18, 2025 | 11:11 AM
Bigoofy's Avatar
Bigoofy
Brake fluid is hygroscopic. This can cause corrosion and reduced brake performance over time. It's one of the only services on this list that I would approve. The other inspections are bogus.
Bluebutterfly
RX - 4th Gen (2016-2022)
Aug 3, 2025 09:50 AM
2023RX350PP
RX - 5th Gen (2023-present)
20
Feb 15, 2025 06:00 PM
wfw
Sep 29, 2022 10:16 PM
Nahpun350
Maintenance
Jun 8, 2019 05:17 PM
