Dyno Chart for LS 500h - max torque?
Old Dec 6, 2023 | 08:50 AM
dan25man's Avatar
dan25man
Question Dyno Chart for LS 500h - max torque?
I know the regular Twin Turbo 500's put out 415 hp and 440 lb⋅ft. And then the 500h total system output is 354 hp, but I can't find any quoted max torque value. Has anyone out there put a 500h on a dyno? Or found a total system max torque value for the 500h? Just out of my own curiosity.
Old Dec 7, 2023 | 03:43 AM
sajack's Avatar
sajack
Default Hybrid Motor Torque
C&D lists LS500h gas engine torque as 257@4900 rpm.
ISEECARS.com shows elec. motor torque as 221.
AWD 4dr Sedan
Drive Train Specs
  • Drive TypeA
  • 4WD Drive Type-
Steering
  • Auto start/stop-
  • Battery saver-
  • Electric motor battery typelithium ion
  • Electric Motor Power Output (Kilowatts)132
  • Electric Motor Torque221
  • EV battery capacity1.1 kWh
  • Hybrid Gas Engine Torque257
  • Hybrid gas Engine Torque@RPM4900
  • Starter typemotor/generator
That would put total torque at 478.
Old Dec 7, 2023 | 09:15 AM
dan25man's Avatar
dan25man
Wow, good digging. I can't imagine Lexus allows 478 ft-lb through the rear wheels. With that number it'd be faster 0-60 than the base 500. I did a little bit of ratio'ing based of these electric motor specs:
Eletric Motor
HP = 177 (132 KW)
TQ = 221
Gasoline Engine
HP = 295
TQ = 257
Quoted Max
HP = 354
So if the max electric motor output when combined with gas is 60hp = that's %17 of total power and %34 of total E-power
So %34 of total electric torque = 75 TQ.
Therefore total TQ (max electric + gas output) = 332 ft-lbs
And based on that total torque value I compared with Lexus's quotes 0-60s times:
Acceleration specs:
LS 500 0-60 = 4.6s
LS 500h 0-60 = 5.1s
11% increase acceleration times
LS500 specs:
HP = 416 (%16 more than 500h)
TQ = 442 (%28 more than 500h)
So I think it's very possible that Lexus allows the combined torque to be above this 332 ft-lbs in order to make it perform closer to the twin-turbo 500. Still would love to see dyno charts for a 500h....
Source: https://lexusenthusiast.com/2017/09/...hnical-review/
Edit: Ok, now I'm thinking there's more torque than that. I used the kenetic energy equation (1/2 mv^2) to calculate what the idealized HP it would be to accelerate a LS500 to 60 mph in the 4.6s lexus quotes, then compare that to the LS500h at 5.1s. So LS500 = 224 HP, and LS500h = 208 HP. About a %7.7 difference in power.
Then I found this dyno chart from Berger Tuning: (for LS500 TT 3.5L engine)
I used this to back characterize the drivetrain losses from the LS500. BHP = 416, WHP = 358 = %14 loss, then for torque, BTQ = 442, WTQ = 433 = %2 loss. So relate that to LS500h. BHP (combined) = 354, WHP = 304.
The thing that's getting me is that power wise it's a %7.7 difference but WHP difference is like %16-17. So now I almost think that the torque value 500h may be higher than the turbo 500 motor to make up the difference.
Old Dec 8, 2023 | 04:55 AM
sajack's Avatar
sajack
Default Hybrid
I passed up a deal on an LS500h because it seemed like “too much sugar for a dime.” I know Toyota is a master at building hybrids, but the complicated transmission setup worried me. I live 100 miles from the nearest Lexus dealer. There isn’t a shop around that has worked on one of these.
I also didn’t feel like the gas mileage was that much better than the standard LS500h.
However, if you own one, it is a beautiful machine and I hope it gives you hundreds of thousands of miles of trouble-free service.
https://www.cars.com/amp/articles/i-hypermiled-the-2018-lexus-ls-500h-from-l-a-to-napa-and-it-sucked-1420700112506/
mistrz11
Aug 10, 2015 07:56 AM
tbilisi79
Apr 19, 2015 07:00 PM
TRDFantasy
Aug 11, 2013 01:17 PM
Hoovey689
May 17, 2013 07:34 AM
LexFather
Apr 12, 2006 10:45 PM
