Suspension noise after refresh
just had all 4 shocks replaced now i’m having a problem with noise inside the cabin over bumps from the rear
the rear shocks now make loud metal on metal noise when going over speed bumps and ride quality from the rear over bumps does not feel correct
parts used: OEM shocks (2) OEM bump stop (2) the only part I did not replace was the top shock mount could this be the source of my problem?
car details: 2012 ls 460 rwd swb 44k miles
edit one more important thing to note the noise comes from the rear left / when bouncing the rear left side of the car shock is very hard to compress
rear left is hard to compress when pushing down on the car rear right is much easier on compression and does not make any noises over bumps
the shop is saying it’s my shock mounts but prior to installation of new shocks the noise was not present. they have taken everything out for inspection and have stated everything visually looks fine but the top mount could be the culprit
all parts purchased from Bell Lexus scottsdale both shocks are brand new and oem from dealer
prior to new shocks the rear left side of the car did not take bumps well this leads me to believe it indeed could be shock mount but I do not understand how that stops compression
good suggestion before the new mounts are installed new vs old part numbers will be compared
after new shocks compression feels extremely smooth on good roads but any time the rear compresses hard on bumps the issue arises
