Control Arm attachment issue
Old May 16, 2022 | 07:09 PM
water2's Avatar
water2
3rd Gear
Default Control Arm attachment issue
Hello,
I've learned a whole lot on this forum -- I really appreciate all of the expertise here - thanks!
I have a 2014 LS460 AWD Base - got new tires and when they went to do an alignment they said my front lower rear control arms were bad. I know a mechanic who has done other work for me, tuneups and the like who said he could replace the control arms. When he went in control arm was fused to something and despite using a blowtorch to loosen it up it wouldn't come out. So then he ended up cutting the piece. Problem is he doesn't know what piece it is, when I showed it to the parts department @ lexus, they didn't know what piece it was (or more likely didn't seem to want to help). I've attached some pictures of it -- can someone help me figure out what this thing is so he can attach the new control arm to the car?
Apparently the outer shell is in the new control arm, but he needs the pieces on either end holding it together? Also picture makes it look bronze, but its actually closer to chrome/silver color if that helps!
Old May 16, 2022 | 11:16 PM
That's the eccentric bolt and the control arm sleeve, they usually rust/fuze together like that.
Old May 17, 2022 | 02:33 AM
Anfanger's Avatar
Anfanger
I had to cut my control arms out in pieces including bolts and sleeves.
Old May 17, 2022 | 03:20 PM
water2's Avatar
water2
3rd Gear
Thanks a lot for your help -- based on this diagram, it is the 48068/48069 and 94151 for the nut? I can't seem to find the sleeve? Are those the only parts?
Thanks!
Old May 17, 2022 | 04:44 PM
Anfanger's Avatar
Anfanger
toe adjust - 2x 48409-50030
toe adjust NO. 2 - 2x 48452-50050
bolt - 2x 90119-16016
Old May 25, 2022 | 08:17 AM
water2's Avatar
water2
3rd Gear
Thanks a lot! That is exactly what i needed
Old May 25, 2022 | 02:40 PM
jdanielca's Avatar
jdanielca
wait u cant buy the sleeve lol....that part of the bushing no ? unless u press out the bushing
Old May 25, 2022 | 02:47 PM
Anfanger's Avatar
Anfanger
It is for AWD, the sleeve is a separate part.
Old May 26, 2022 | 11:34 AM
jdanielca's Avatar
jdanielca
oh cool thats interesting .good to know.. stand corrected
mdpresco
May 30, 2024 08:40 AM
stopdrpnro
Jan 5, 2021 09:45 AM
k311in
Apr 24, 2018 05:02 PM
youngs3oo
Suspension and Brakes
Oct 24, 2013 03:57 PM
Toshihiro
IS - 1st Gen (2001-2005)
Jan 10, 2012 10:36 AM
