LS600 led headlights - who has them? read inside pls
Old Feb 1, 2022 | 06:52 AM
miket000's Avatar
miket000
Originally Posted by jdanielca
Are you talking about Nike nights at the corner ? Those are not the drl in the 460, the drl in the 460 is running low voltage on the high beam bulbs
I thought these 600 Nike lights in the corner were the drl? Funny, previously when I read Nike lights, I always thought people were talking about the aftermarket door projector lights. I thought somehow the Lexus L might look like a Nike N on the ground. Seems rather a dumb thought now that I think about it.
Ah yes, you're right 460 high beams just look dim now that you refreshed my memory...
Are these what you refer to as Nike lights? Maybe that is just a reflection I'm seeing.
Old Feb 1, 2022 | 09:10 AM
jdanielca's Avatar
jdanielca
to have Nike lights on the 460/600 come on by themselves you turn on the parking lights, which is one step above off, then your tail lights come on and led at the corner of the 460 near the grille comes on as for 600 I gotta go look closely
Old Feb 1, 2022 | 08:01 PM
monza's Avatar
monza
6th Gear
The drl (day time running lights) on our type of 600 headlamp are a separate small yellow bulb. It looked incandescent to me due to the color. I have them turned off on all of our cars so I'm going off memory. From what i remember 460 and 600 drl looked the same.
Monza if you have 1 side not working I'd turn off the drl feature using techstream.
hi Mike
thanks for the response
how do I access tech stream? Is there a in car menu to switch on/off the DRL?
I also read from another thread that the DRLs cannot be replaced , entire headlight assy must be replaced !
Old Feb 1, 2022 | 08:02 PM
monza's Avatar
monza
6th Gear
Originally Posted by swfla
Hi Monza, here's a link to a recent discussion of similar issue. https://www.clublexus.com/forums/ls-...ike-light.html
QUOTE=monza;11217608]Hi
i got the ls600 led headlamps:
does anyone know how to repair the daytime running lights? Mine has gone kaput
[/QUOTE]
so the entire headlight assy must be replaced?
Old Feb 1, 2022 | 08:58 PM
miket000's Avatar
miket000
Originally Posted by monza
hi Mike
Your welcome. On newer cars you can turn the drl's on or off using the nav display menu's. On older models Techstream must be used. There are versions of techstream for purchase on amazon for $30 or so.
If you have a good relationship with your dealer they might turn it off for free, either using their computer with techstream or doing it through the nav display, if that is possible with your model year.
Old Feb 1, 2022 | 11:05 PM
jdanielca's Avatar
jdanielca
hi Mike
it’s really depends on what you mean by cannot . As in the dealer and most places won’t be able to fix it , probably. It also depends how handy you are lots of people modify their own headlights, so repairing the module if it’s not working would involve opening the headlights. I bought some spare led modules for my headlights off yahoo auctions Japan.. I don’t know which yours uses if it’s a board etc. try Googling for pics with the light taken apart
Old Feb 3, 2022 | 06:02 AM
monza's Avatar
monza
6th Gear
Can anyone provide the part number for LH and RH led headlamps? Do they require programming for RHD cars? Mine is RHD based in Singapore.
or the headlamps are just plug and play?
thank you
Old Feb 3, 2022 | 06:00 PM
jdanielca's Avatar
jdanielca
thank you
have you bought them? Best bet for SG is to buy them from yahoo auctions Japan they need to br resumed they parts are the same. If you buy it from US shipping will F u, dm me if you need info kakilang sg
Old Feb 4, 2022 | 09:16 AM
indypwr's Avatar
indypwr
question, how do you guys like the ls600 headlights compared to the old ones?
im also thinking of going this route but they are quite expensive.
thanks!!
Old Feb 7, 2022 | 08:25 AM
jdanielca's Avatar
jdanielca
Hmm I thought I replied, I have not compared xenon to led side by side I would assume since it’s 2007 led tech it’s not going to be as great as xenon try asking or googling to see how far the Xenon beam
goes this goes about 10meters. It does look a TON better aesthetically speaking, The key as you can see from my posts is to get it properly aimed which can mean 5m as opposed to 10. Also the high beams can be converted to bixenons/leds that involves opening up the lights to change the projectors and some wiring that would give you the best of both worlds but cost you money.
for those interested in ls600 headlights and fogs dm I’ll make you a deal, it’s gonna be cheap but cheaper than buying on eBay etc
User 122922
Jul 24, 2021 12:27 PM
jz14
ES - 7th Gen (2019-2025)
Dec 29, 2018 01:02 PM
simplecar
RX - 1st Gen (1999-2003)
Sep 19, 2018 09:15 PM
moltenrcf
RC F (2015-present)
Apr 23, 2018 11:52 PM
tx8koibito
NX - 1st Gen (2015-2021)
28
Oct 7, 2017 09:49 PM
