LS or ES for comfort.
The story goes.
I wanted a Cush vehicle so I was sold on a less than $25k used ES. One that drives like your on a cloud. I was bit by the SUV bug and bought a top of the line 2021 turbo Mazda CX 5. Didn’t like it, way to rough of ride. Sold it.
Now Im back in the market for the cushy, I’m on a cloud ride. Car under $25k.
Through my research and a couple limited test drive of a 2017 Es 350. Not so sure that model is like riding on a cloud.
Are any of the ES 350 a cushy type of ride? Should I not give up on the less expensive 350 model ?
If not which year of LS should I look at. Thanks
I'm surprised you found the CX-5 a rough ride. One of my employees just got one and its really nice. Obviously nothing like an LS.
For year, as new and as low mileage an LS as you can get. $25k you're likely priced out of a 13-17 model
The story goes.
My ES's were a 1990 ES250 and a 2002 ES300.
My LS's were a 1997 LS400 and my current 2008 LS460.
The biggest difference between all of them besides price and fit & finish was road noise, and maintenance costs.
The ES is based of the Camry/Avalon, and until 2018, they shared the majority of mechanical components. This makes ES's pretty cheap to maintain (not at the dealer). Cumulative total between 3 of my older Lexus' cars, I spent less on all of them over their lives than Lexus wanted to do one repair on my LS460. The dealer wanted $3,500+ to do the control arms and ball joints on it. I did them in my garage for $350. If you are not handy with a wrench, or don't know someone who is (or can get it repaired cheap at an indy shop), I would go with the ES. The most expensive thing to go wrong on my 2002 ES300 was a catalytic converter. From Toyota they were $900. Got one installed at a muffler shop for $250.
The LS460 takes NINE quarts of oil, and has 2 air filters. Front end suspension components only last 100k, less if you are hard on it. Older ones, air suspension can be problematic. and then there's the big ticking time bomb. The brake actuator...a $4,000 repair at Lexus (what I was quoted at Park Place). It can be done cheaper (about $2500) at an indy, but they have to have proprietary software to set it up and bleed the system. Check to see if that has been done. If not, pass on the car. Brakes are pretty spendy too, but last awhile. If you're handy or have plenty of disposable income, the LS is a wonderful car. the LS460 has by far been my favorite for the combination of comfort, power and fuel economy. It's better on fuel than my 2002 ES300 was too, largely due to having more gears. I will say, to date, the LS460 (I am 2 years into ownership in december) has cost me more than the other 3 cars combined in maintenance. But, its all done now, should be another 100,000 miles before it needs anything else. I also do 99% of my own work. The only work I didn't do on the LS was the lower ball joints, because they are pressed into the spindle and I lack the tools (hydraulic presses) to remove them.
TLDR: Comfort, power and highway fuel economy, can't beat the LS460. They just eat highway miles like nothing. Cheap/easy maintenance, city fuel economy, and age of car important to you? Grab an ES. You can't go wrong with an ES, it will serve you well for many years.
In the end, they are just cars, and most cars are similar enough that any technician can work on them. The only time you run into issues with indy's is when they don't have the proprietary software needed to diagnose or repair the car's systems. Mechanically, an engine is an engine, suspension is suspension, transmission is a transmission, etc. If you can fix one, you can fix most. If you can't, you need to be either friends with a guy like me, or ready to hand over dough.
I changed my blower motor the other day because it was making a god-awful racket. Ruined the entire LS driving experience. Sounded like a lawnmower under my dash. Lexus wanted $1500 to change it. The Denso part was $165 on Ebay (new old stock) and It was literally 3 screws, a plug, and 15 minutes of work to change it.
