Chaulky white interior - help needed
Old Sep 26, 2021 | 03:51 PM
swfla's Avatar
swfla
Stickydashfix looks like a great product, johnnyg66 had great results.
Old Sep 26, 2021 | 04:47 PM
Originally Posted by Sibby1979
Do you think that would be a temp fix or something that needs to be done on a regular basis?
You only have to do it once as long as you wipe the panels down with something like 303 Protectant once in a while. In other words don't let it get sun damage again.
Old Sep 27, 2021 | 04:42 AM
Sibby1979's Avatar
Sibby1979
I have been using 303 for a while now but the trim turns back to the chaulky white.... i have tried this on other panels also.
Will try and heating it and see if applying 303 afterwards helps. thanks
Old Sep 27, 2021 | 11:14 AM
Hmmmm, then I wouldn't keep using 303. Be very very careful with the heat gun can't stress this enough, also do a test on the least visible area it might not work at all. Seeing that plastic seems to keep oxidizing (or whatever process is causing that) you may have to paint them with SEM Classic Coat.
NeraBlu
Automotive Care & Detailing
Jul 9, 2021 11:43 AM
rotaryrock
Aug 2, 2012 09:28 AM
BertL
RX - 3rd Gen (2010-2015)
12
Dec 22, 2011 02:42 PM
Francis
CT 200h Model (2011-2017)
Sep 28, 2011 09:00 AM
