Front brakes bleeding question
Old Jul 31, 2024 | 05:04 AM
  #61
ampgarage's Avatar
ampgarage
4th Gear
Default linear valve offset not completing
Originally Posted by ALK
linear offset valve calibration procedure does not require bleeding or unplugging . Here i have a video Its in arabic just follow the video . Car must be on a level ground and the steering wheel must be straight .
https://www.youtube.com/watch?v=UjDNeMXeRRI
Hello guys, I have Lexus CT200h 2011 been trying to do the linear valve offset calibration but its not going through, sometimes it stops by second between (20s to 15s) and lights go solid never getting the quick flashing, sometimes even it goes even beyond 120s and it is still trying to calibrate then lights go solid and calibration would not take place,, i have tried bleeding multiple times but cant seem to be able to make the car perform the offset valve calibration.. any ideas ?? note i use maxis scan tool..
Old Jul 31, 2024 | 07:36 AM
  #62
Boykie's Avatar
Boykie
ABS actuator is gone.
Old Jul 31, 2024 | 08:19 AM
  #63
Gerf's Avatar
Gerf
What was the initial problem that caused you to try this?
Old Jul 31, 2024 | 09:46 AM
  #64
Its dead, you will need a new actuator
Old Aug 1, 2024 | 03:05 AM
  #65
Gerf's Avatar
Gerf
So, I see in your thread in the CT forum you found the problem to be procedure and not the actuator itself ?? https://www.clublexus.com/forums/ct-...performed.html
Old Aug 1, 2024 | 10:40 AM
  #66
Oh that's funny. Yeah if he never bled it it won't work, we were assuming he did all that since you are supposed to
Old Aug 1, 2024 | 12:01 PM
  #67
Gerf's Avatar
Gerf
He seems like a fairly fart smellow.
Mar 22, 2021 03:07 PM
LexBrett
Oct 16, 2015 06:42 AM
whitecel
Suspension and Brakes
Dec 18, 2013 03:40 PM
DH_GS430
Nov 11, 2009 05:36 PM
thaamish
Jul 13, 2007 08:54 AM
