2008 LS460 Broken Navigation Bezel DIY Replacement
Old Mar 13, 2021 | 04:05 PM
Zoraone's Avatar
Zoraone
Default 2008 LS460 Broken Navigation Bezel DIY Replacement
As with many older LS460s, my navigation bezel was cracking at the top of the HVAC vents. It didn't bother me at first. However, they continued to crack and I knew I wanted to find a solution. My options were to either buy one of the faux wood kits that would cover the cracks or buy a replacement bezel.
I went with buying a replacement bezel and swapping over all the components (NAV, Nav/HVAC interface buttons, clock and emergency flasher button).
Overall I would say this was not terribly difficult. However, it did require some attention to detail as there are a number of clips and screws that need to be removed and swapped over correctly for everything to function well.
Below is the DIY I created for anyone wanting to attempt this swap. As with all DIY, this is how I did it. There may be other, better, ways to complete this. Please attempt this at your own risk. Nav units aren't terribly expensive used, but I'd hate to have dropped it and completely destroyed everything.
In addition, I have likely missed something in the DIY steps below, but I hope it helps anyone wanting to see the process first before attempting the swap. Again, it wasn't difficult, just more time consuming given you have to remove all of the components from the car first (without breaking anything) and then swapping over the components from the old unit again without breaking anything.
Part Information:
  • New Bezel Part # 55405-50110 (MY 2008 LS460) - Note, I believe the 2010 - 2013 part is different so do your homework if you have that model year car as this part doesn't fit the newer cars.
  • Cost: $260.31 plus shipping
  • Total Time: Approximately 3 Hours
Tools Needed
  • Various interior removal tools (plastic)
  • 10mm and 8mm ratchet with short extensions to remove the CD and NAV unit from the car.
  • Various Phillips head screw drivers
  • Some cloth tape (gaffer or duct)
  • Navigation screen safe cleaning wipes (just to clean off dirt around the screen as well as finger prints).
Additional DIY Resources
  • 2007 How to Remove Radio / Navigation / CD Changer DIY -
General Notes:
  • Just be careful. Removing the old components can crack/tear/break the dash components (especially if you have a melting dash) and the plastic is fairly brittle.
Old Mar 13, 2021 | 05:58 PM
comotiger's Avatar
comotiger
Zoraone, thank you for provided such detailed instructions. You have taken a lot of time and effort to document and clearly label all the steps. I wonder if you are a teacher!
I will never need these instructions, but I am sure they will come in handy for many. Great job!
Old Mar 13, 2021 | 06:15 PM
Zoraone's Avatar
Zoraone
Thank you.
No, I am not a teacher. However, I greatly appreciate all the DIY knowledge online and try to contribute if possible.
Thank you again and have a nice evening.
Zoraone
Old Mar 13, 2021 | 06:47 PM
johnnyg66's Avatar
johnnyg66
I was lucky to find a good used one on ebay for $100. It came with all the buttons i just had to swap over the Nav screen.
Old Mar 13, 2021 | 08:37 PM
ALK's Avatar
ALK
I am waiting on my bezel to arrive. The old one broke to pieces after swapping the whole dash. Also make sure the two screws are installed. Mine were missing.
Old Mar 14, 2021 | 01:08 AM
bpddaddy's Avatar
bpddaddy
@Zoraone Thank you. I will be doing this soon as my wife asked me if I were ever going to repair mine.
Old Mar 14, 2021 | 11:13 AM
JLAWS's Avatar
JLAWS
Wow, very detailed! I was the first to do the bezel swap and made a post. But I'll refer to yours if I ever have to do it again
Old Aug 11, 2023 | 12:11 PM
rowyd1983's Avatar
rowyd1983
7th Gear
This thread was very helpful! The climate audio disp info buttons were not working on my car. I ordered the buttons off of ebay for $40 followed this thread for dismantling and reinstalling and everything works like a charm. Thank God for this forum and its contributors.
Acrad
GX - 2nd Gen (2010-2023)
155
Oct 4, 2021 05:59 PM
babaijebu
Aug 24, 2020 03:32 PM
YannG
Oct 25, 2019 11:54 AM
umarali
LX - 3rd Gen (2008-2021)
Oct 7, 2015 10:10 AM
MattStarr
Jul 31, 2011 02:35 PM
