2009 LS460 Engine swap??
Old Mar 3, 2021 | 11:23 AM
ThomBradie's Avatar
ThomBradie
Default 2009 LS460 Engine swap??
I have a 2009 LEXUS LS460 RWD and I was wondering if anyone knows what the best engine swap would be for it. If so, what’s a price range and what info I need for it and if anyone has done it. I heard the is F engine but haven’t head of the GS F engine. I straight piped mine and it sounds great but not loud enough at all or fast. And no I don’t want to get a new car.
Old Mar 3, 2021 | 11:30 AM
What's your budget?
Old Mar 3, 2021 | 11:56 AM
Caflashbob's Avatar
Caflashbob
You are in California. Smog laws?
Old Mar 3, 2021 | 12:31 PM
ThomBradie's Avatar
ThomBradie
Right now all I want to know is what everything I will need and then figure out the $
Old Mar 3, 2021 | 12:32 PM
ThomBradie's Avatar
ThomBradie
Yes I am and yes smog laws are here in California I do not know the exact but I will have to do that research once I figure this all out.
Old Mar 4, 2021 | 03:53 PM
Caflashbob's Avatar
Caflashbob
If you swap a motor I think you would need all the electronics and exhaust cat stuff also
Old Mar 4, 2021 | 06:35 PM
sdls's Avatar
sdls
You’re not going to do this engine swap you asked about. Now I know for certain
Old Mar 4, 2021 | 08:01 PM
Caflashbob's Avatar
Caflashbob
You might try oxygenated race fuel? Put some in an old car long ago and was amazed.
Cheaper. Dilute it.
Old Mar 4, 2021 | 10:09 PM
ALK's Avatar
ALK
I know a korean guy who swapped 3rd-gen GS460 with an ISF engine. Yet there is a russian guy with a 3IS swapped with a RCF engine . Question is how much are you willing to spend?
Old Mar 5, 2021 | 05:46 PM
LeePowers's Avatar
LeePowers
Check out Monkey Wrench Racing outta MI.
They make stuff for LS460.
Camshafts,a MID Sleeve kit, I think even a stroker kit. Maybe the stroker was for the 3UR.
None of it looked cheap,and I'm not sure if a tune was included.
Even trying to turn 1UR into a 2UR with factory parts, sounds expensive.(Though I would have loved to have tried.)
Old Mar 5, 2021 | 06:00 PM
sdls's Avatar
sdls
Traditionally Toyota’s FE and GE engines had intrinsic cylinder head differences like different valve angles in addition to larger diameter valves and higher performance camshafts. I don’t know about the URs case but it won’t be as simple as adding a trick camshaft to the 1UR-FSE to make it flow like a 2UR-GSE. If you must have more power with the LS460 engine then the only way to go is some kind of forced induction.
aazz
Aug 29, 2024 07:25 AM
ie9org
LX - 3rd Gen (2008-2021)
Mar 4, 2021 07:09 AM
Rotary13b
Nov 20, 2020 05:34 PM
hirollr865
Aug 20, 2020 03:34 PM
Gonzae92
Nov 1, 2019 08:59 PM
