Finally DRL/ high beam solution is here... really
Old Dec 15, 2020 | 11:19 AM
jdanielca's Avatar
jdanielca
Default Finally DRL/ high beam solution is here... really
So I’ve contacted retrofit source according to them the morimoto 3.0 coupled with PWM module from GTR https://www.theretrofitsource.com/gt...MOD?quantity=1 will give us working drl/ high beam.
post some photos when you guys install them.
Old Dec 15, 2020 | 04:51 PM
BiGEZ's Avatar
BiGEZ
Good find I will check it out as they are local to me. Just picked up a 2011 AWD to add to the stable. Do not like the yellow DRL/high beams.
Old Dec 16, 2020 | 05:09 AM
lwphat66's Avatar
lwphat66
So this particular PWM module will be able to eliminate flicker AND dim LED bulbs in our 460s?
Old Dec 16, 2020 | 08:25 AM
jdanielca's Avatar
jdanielca
not only the PWM module but also the bulb, apparently everything works together the pwm module is 50 so I’ll just get it just in case but the tech difference is the bulb the old 2.0 bulbs won’t work
Old Dec 16, 2020 | 09:03 AM
AZGS4's Avatar
AZGS4
50 for the module and 175 for the LEDs, so 225 plus whatever shipping costs. It looks like the LEDS are not DOT approved for use as headlights, but can be ordered as "fog light" use only.
Old Dec 16, 2020 | 09:25 AM
jdanielca's Avatar
jdanielca
as are all led bulbs but who cares you think someone is going to do anything about it? Nope coz that will trigger a lawsuit lol
Old Dec 16, 2020 | 10:05 AM
AZGS4's Avatar
AZGS4
I didn't realize all LEDs are not DOT approved for headlight use.
Old Dec 16, 2020 | 11:36 AM
BiGEZ's Avatar
BiGEZ
Parts ordered I will update once received and installed.
Old Dec 16, 2020 | 04:27 PM
lwphat66's Avatar
lwphat66
Cool, thanks for the info!
Old Dec 16, 2020 | 06:51 PM
jdanielca's Avatar
jdanielca
great man let us know
Old Dec 17, 2020 | 08:02 AM
naterdee's Avatar
naterdee
I just replaced my high beam halogen bulbs with some LED's off ebay for 20 bucks. DRL's work fine, highbeams work fine. Not sure why you would need to spend that much.
https://www.ebay.com/itm/2pcs-HID-Wh....c100005.m1851
Old Dec 17, 2020 | 08:21 AM
AZGS4's Avatar
AZGS4
Would you post pics of both the DRL and Highbeam functions please? What year and model LS did you install them in?
Old Dec 17, 2020 | 09:01 AM
naterdee's Avatar
naterdee
High beams with HID's on : https://ibb.co/302P7Lb
DRL's on: https://ibb.co/Cpc5PP7
Old Dec 17, 2020 | 09:42 AM
AZGS4's Avatar
AZGS4
Looks good and the DRL's seem to be white and not yellow. The LED's are 6000K based on the ebay link you sent. What is the color temp of your HID's?
Old Dec 17, 2020 | 09:56 AM
fwhomeboy's Avatar
fwhomeboy
That Note 10 has a great camera.
