2011 Control Arms?
Old Nov 20, 2020 | 03:59 PM
Lskevin's Avatar
Lskevin
Default 2011 Control Arms?
So I’ve been looking for a while and finally found a pristine ‘11 LS with 57k miles and am pretty stoked.
When/how should I be concerned about the control arms I’ve been reading about. It rides like it’s on rails now.
Thanks for any insight, and although I’m new here, I couldn’t find any existing threads on it.
Kevin
Old Nov 20, 2020 | 04:09 PM
Anfanger's Avatar
Anfanger
If control arms are in good shape, you are probably OK for couple years. I would take turns easy, it will extend life of control arms.
Old Nov 22, 2020 | 05:29 AM
Lskevin's Avatar
Lskevin
Ok, thanks for your reply.
Dumb question - is the wear something that can be felt while driving, or does it need to be inspected while on a lift?
Old Nov 22, 2020 | 08:07 AM
Anfanger's Avatar
Anfanger
If it is severe, you will definitely hear and see it. Uneven wear of tires is one of signs. Wore down arms can be identified on a lift, it is actually a good practice to check on them periodically. Check the arms every oil change. It does not take long and can be done at home using ramps, a small mirror and a light.
Old Nov 22, 2020 | 11:42 AM
RR601's Avatar
RR601
Also was this something that was corrected later. If you replace them should new ones have a longer lifespan?
And are they effected by age or just miles
Thanks
Old Nov 22, 2020 | 12:03 PM
Anfanger's Avatar
Anfanger
Thanks
I cut in pieces 10-year old arms and rubber had no decay sings on it except the cracks. My personal believe is the control arms are damaged by aggressive cornering, rough roads and not good engineering for such heavy vehicle.
sktn77a
Sep 7, 2024 11:31 AM
EZZ
Nov 20, 2020 04:08 PM
tomr51
Aug 19, 2020 08:46 PM
JimK2
Dec 24, 2015 12:15 PM
