Odyssey Battery
Old Jan 31, 2019 | 01:14 PM
johnnyg66's Avatar
johnnyg66
Default Odyssey Battery
After 3 years i had to replace the Red Top Optima. The last few weeks it felt slow to start and if i left the accesseries on for a few mins less than 5 the dash would say low battery start car to charge. I bought a Topdon tester on amazon after reading some good reviews on line. It tested the optima and said replace. I ran the test several times on a cold battery and hot with same result.
After sometime i chose the Odyssey 34-PC1500. 4 year warranty and 850CCA. The Red Top was 720CCA. As you can see in the photos the test results for both. I bought it from the Odyssey web site. Funny thing is it shipped from a battery depot in Florida and only took 2 days to get here.
The tester can also test charging and starter status. All came back good just the battery failed. This will probably be the last battery i will buy for the LS. By time it goes i will be done with the car.
My old LS i had a interstate and it did well till i sold it. That was a normal type not a AGM.
Total cost with needed spacer was $310.00
720CCA
850CCA
Old Jan 31, 2019 | 01:30 PM
DedBirdDog's Avatar
DedBirdDog
Doesn't the Optima have a 3 year warranty? Using a 30% off coupon from Advance Auto a new Optima is $162 before taxes. I'm sure the Odyssey is a great battery but is it worth almost 2X as much?
Old Jan 31, 2019 | 01:34 PM
johnnyg66's Avatar
johnnyg66
Yes, Optima has a 3 year. There is been some talk about who owns Optima now and it has lost some quality. Make sure you register your battery or that 3 year is useless.
Old Feb 1, 2019 | 08:33 AM
aw001's Avatar
aw001
Wonder if we can reach a consensus on the best battery for LS 460- RWD vs AWD. I am thinking of changing mine out soon.
Old Feb 1, 2019 | 10:34 AM
UZ214's Avatar
UZ214
I got mine from Costco, interstate (cold weather package) suppose to have more cracking power; cost me about 90$ after turning the old one in. Its not me cheapening out, I think their batteries are just as good plus anything with an issue Costco is awesome customer service.
Old Feb 1, 2019 | 01:31 PM
johnnyg66's Avatar
johnnyg66
I say its a matter of opinion. So many batteries are made by the same plant. I liked the 4 year warranty on mine, etc. I have tried many batteries over the years. For some it comes down to cost. So buy whatever you want.
Old Feb 1, 2019 | 02:02 PM
Caflashbob's Avatar
Caflashbob
The local pep boys manager mentioned that my Bosch AGM battery if ordered on the west coach was built by Johnson Controls and if east coast was East Penn.
too much money to ship across the USA
Old Feb 1, 2019 | 02:26 PM
jdanielca's Avatar
jdanielca
what kind of specs do we need on the battery if there are any?
Old Feb 1, 2019 | 03:00 PM
Really disappointing a premium battery like the Optima Red Top would fail after 3 years
Old Feb 1, 2019 | 03:08 PM
Caflashbob's Avatar
Caflashbob
Agm’s in general are more sensitive to overcharging at higher battery temps.
Factory panasonic battery was probably a flooded cell VRLA for a reason. Extreme quality. High dollar. Can take a higher voltage charge at elevated temps better than a AGM.
factory $700 battery may triple the life of others that cost 1/3 as much..,,
you might think Lexus knew what they were doing when the designed the specific battery for their car or something....
Old Feb 1, 2019 | 03:22 PM
DedBirdDog's Avatar
DedBirdDog
The P/O of my 2013 replaced the battery with an OEM Lexus battery after 50 months after it failed a health check at the dealer in January of 2017. When I got the car, I checked the battery level and it was low. I had to add distilled water to all cells. That battery is a 680 CCA battery. My take is that if you live in colder climates, the extra CCA is a good idea. There's no way I'd ever go with an OEM battery for this car unless it was a warranty replacement. The cost is simply ridiculous.
https://www.lexuspartsnow.com/parts/...800-38100.html
You can use the online coupons from Advance and get an Autocraft Gold 700 CCA battery with a full 3-year free replacement warranty for around $100 all day long. IMO, that's probably all the battery anyone would ever need. I just don't see the merit of these high-priced batteries.
Old Feb 1, 2019 | 03:42 PM
There are two different OEM batteries. The ones that are sold at the dealership are not the OEM Panasonic batteries that come with the car, that one in that link is. So the previous owner didn't pay $800 for that battery.
Old Feb 1, 2019 | 04:17 PM
KYLS's Avatar
KYLS
CL Folding 500,000
You made an excellent choice with the Odyssey battery. I've had a DieHard Platinum, Group 34 (Rebranded Odyssey 34-PC1500) in my LS460L for 6 years now, and it is still going strong. Sears gave it a 10 year full replacement warranty, so they either knew it would stand up, or that they wouldn't.
I have/had the PC1750 size in my Landcruiser and Q-45 (recently sold) for even longer, with zero issues. You won't have any issue with terminal corrosion, or potential damage from acid boiling out, like a traditional flooded battery. If you do draw down the Odyssey and need to deep charge, then be sure to use a charger rated for AGM, like the "BatteryMinder 2012-AGM".
BTW:
Odyssey 34-PC1500T on Amazon for $296 Odyssey 34-PC1500T on Amazon for $296
Old Feb 4, 2019 | 02:26 PM
aw001's Avatar
aw001
I guess i will go for diehard platinum. I asked at my local costco and was told they do not have compatible battery for 2014 LS 460 AWD... weird..
Old Feb 4, 2019 | 02:28 PM
aw001's Avatar
aw001
anyone can comment on duralast gold (27 DLG) from autozone?
