Pad wear warning light
Old Dec 2, 2018 | 07:38 AM
jdanielca's Avatar
jdanielca
Default Pad wear warning light
So I’ve got a pad wear warning light before I waste time taking it some place, I just got my pads checked maybe 2 months ago I was told it was good. So could this be an error and where are these sensors located can the light be reset?
Old Dec 2, 2018 | 09:02 AM
213374U's Avatar
213374U
The pads will still have some life left when the wear sensors are hit; they "look good" to anyone just visually checking. They are located on the pads themselves and must be replaced once worn through. The light will be reset when you replace the pads and sensors.
Old Dec 2, 2018 | 09:34 AM
jdanielca's Avatar
jdanielca
i read some place on the 07 they are not on all pads... do u know if this is the case?
Thanks for responding
Old Dec 2, 2018 | 10:25 AM
sha4000's Avatar
sha4000
The 07 only has them on the passenger side front/back.
Old Dec 2, 2018 | 04:32 PM
jdanielca's Avatar
jdanielca
good to know thanks so do people change pads like they change tires left and right side at a time or do I have to change all 4 ?
Old Dec 2, 2018 | 04:38 PM
stasek's Avatar
stasek
Usually, the front pads will wear out quicker.
Old Dec 3, 2018 | 07:20 AM
sha4000's Avatar
sha4000
Change both front side pads or change both rear side pads. Or change all front/rear pads.
Old Dec 3, 2018 | 09:13 AM
ldmf's Avatar
ldmf
I also have recently received the pad warning light. I checked all four sets and they all have at least 1/4 of an inch left. Being that start out at approximately a 1/2 inch, is a 1/4 inch the safety margin built in? Seems like I have another 4-6k miles left on these. let me know your thoughts.
Old Dec 3, 2018 | 10:28 AM
213374U's Avatar
213374U
I mean, you can ride em till they squeal and just deal with the dash light, how long you wait to do the work is ultimately up to you. But the point is the light will stay on until you replace the damaged sensor and install pads that extend well beyond the new sensor.
airlaird
RC F (2015-present)
13
Jun 7, 2018 03:36 PM
MnGs3xx
Mar 13, 2016 05:29 PM
kevintown
Nov 17, 2012 10:06 PM
Frank T
Feb 6, 2008 11:57 AM
JDMCelsior
Dec 20, 2006 11:38 PM
