PSI computer display is off 2-4 PSI
Old Jul 26, 2018 | 11:17 AM
jrmckinley's Avatar
jrmckinley
Default PSI computer display is off 2-4 PSI
2010 460L owner. I've read a decent number of threads in here about where people keep their PSI (seems like 33 is the consensus). My computer has always shown 36-38 but my service dept always checks them and has documented during each oil change & tire rotation they have PSI at 33. I've never been bothered by it as I typically don't keep that displayed and always figured I'd rather it be a bit high than low. I was reading in the Car Chat forum about tire pressure gauges and ultimately bought one from Amazon (an AccuTire model) which showed 33 on 3 of my tires and 32.5 on the other. My computer shows 36 on all at cold start and up to 38 as I drive. I'm choosing to trust the device since my tires were just checked last week at a mechanic and read 33 and now I'm getting the same reading with my new gauge.
At least now I know the margin of error on the computer is somewhere around 3 PSI. If I ever see the computer display around 33 I'll do a manual check and assume I may have slightly low air. Anyone else have that big of a discrepancy?
Old Jul 27, 2018 | 08:56 AM
jmcraney's Avatar
jmcraney
I believe that if you study this more carefully, you will conclude that the pressures displayed in the dash accurately reflect the pressures in the tires.
Old Jul 27, 2018 | 06:56 PM
Caflashbob's Avatar
Caflashbob
I have a set of tire valve stem pressure senders mounted on the car.
the cars TPMS is 2-3 psi higher. Always. As posted above.
same senders on our sc. both double checked with multiple precision gauges
Old Jul 27, 2018 | 07:10 PM
jmcraney's Avatar
jmcraney
I stand by my comment.
Old Jul 27, 2018 | 07:52 PM
Caflashbob's Avatar
Caflashbob
Is the tire pressure higher at the TPMS sensor than the end of the stem?
Old Jul 28, 2018 | 12:11 AM
jrmckinley's Avatar
jrmckinley
Out of curiosity, why do you say that? The computer is the outlier by several PSI compared to what tire shops and my new device are getting. I would argue that gives me little/no confidence in the computer since various tire shops that check the pressure and now a digital gauge are coming out with the same readings...
Old Jul 28, 2018 | 03:27 PM
sha4000's Avatar
sha4000
Sometimes it's accurate but most of the time it's off 1 to 2 psi when I check it.
Old Jul 28, 2018 | 04:19 PM
Duck05's Avatar
Duck05
They are a good tool to keep a watch on the tire pressure. If you have swings on the display, best to have a tire pressure gauge in the car to check where you stand and react accordingly. I have put portable air pumps in all the cars to at least have a quick way to correct a low tire and then get to a tire shop...….
Never expected these systems to be "nuts on" given all of the variables....
Old Jul 28, 2018 | 04:27 PM
jud149's Avatar
jud149
I don't find much difference between my tire gauge and dash read out. The most important thing to me, however, is tire wear. I want it even.
Old Jul 30, 2018 | 02:35 PM
GhostB's Avatar
GhostB
Default Tpms
2010 LS460. I pumped my tires last week at Shells gas station. It was a digital pump. I set it to 34 psi. My dash displayed from 35-37 psi for all tires. I will just check it every month just to be sure. Doesn’t bother me tho. Maybe the factory air suspension could be a factor.
SolidG1
GS F (2016-present)
Aug 30, 2025 07:47 AM
rxets
RX - 3rd Gen (2010-2015)
Dec 11, 2009 08:35 AM
twister
Dec 24, 2007 07:11 PM
9520G
Sep 13, 2006 04:54 PM
lex430
Wheels, Tires & Brakes Forum
14
Apr 20, 2002 09:33 PM
