Kinked Radiator Hose?
Old May 28, 2018 | 07:55 PM
RNelson's Avatar
RNelson
Default Kinked Radiator Hose?
Hi Everyone,
I just bought a LS460, unfortunately from a Mercedes Dealer. They did go through the entire car and found a leaking radiator and replaced some hoses as well as the radiator. I don't really know exactly which hoses were replaced. This weekend was the first week I had the car and I just did my own inspection. I found on the passenger side, right behind the radiator, a radiator hose, it looks like it is going from the engine to the bottom passenger side of the radiator. It comes from the engine going down, then it bends going forward then bends going down and then forward again attaching to the radiator. At all bends it seems from looking down that the hose is kinked and actually looks like it is kinked flat. Look at the images below, the arrows are pointing to the bends and flat spots. The picture is taken looking down from above the engine. What is going on here? Does anyone have any pictures of this hose to reference? Should it bend like this?
Old May 29, 2018 | 08:28 AM
JLAWS's Avatar
JLAWS
Can't really fully see how kinked it is. Maybe you can take off the bottom cover and snap a few shots from below? It is either put on backwards or they used a Mercedes hose they had in stock that they figure was close enough.
Old May 29, 2018 | 08:44 AM
sha4000's Avatar
sha4000
I can see the kink and that looks like a recipe for disaster.
Old May 29, 2018 | 07:45 PM
RNelson's Avatar
RNelson
I'm taking it there tomorrow and I will ask about it. Hold for the update.
Old May 29, 2018 | 09:29 PM
RNelson's Avatar
RNelson
Here is a schematic of the hose in question....
Old May 30, 2018 | 04:29 PM
RNelson's Avatar
RNelson
Well they inspected it today and said all looks fine. I was just wondering if anyone on the board has had a good look at this hose to let me know if this is the standard appearance as it is an "S" shaped hose...
Old May 31, 2018 | 04:52 PM
roadfrog's Avatar
roadfrog
This is a common problem, but at least you sorted it out quickly. I had a similar issue when I changed out my upper and lower hoses. The one similar to yours was also kinked and obviously too long (causing the kink). Even though the part numbers were the same on the hose, it was clear that the hoses differed. The correct hose was about an inch shorter a the end that attached to the rad.
Old Jun 1, 2018 | 08:46 PM
sha4000's Avatar
sha4000
So he still has the incorrect hose installed.
Old Jun 2, 2018 | 05:39 AM
roadfrog's Avatar
roadfrog
So it would seem.
Old Jun 2, 2018 | 06:45 AM
sha4000's Avatar
sha4000
I would make sure the correct hose with no kinks is installed. A kink in the hose will restrict the flow and with the hotter weather coming you need your cooling system in tip top shape.
Old Jun 2, 2018 | 02:17 PM
RNelson's Avatar
RNelson
Yeah, I think the Mercedes tech obviously does not know what he is looking at. I just wanted to get my car out of there. The temperature seems to be fine, I'm watching it closely. I will jack up the car next weekend and verify for myself. bummer is that if I do want to replace it I am going to basically have to change out all of the coolant, that was just changed, what a waste. I'm going to have to do a search and find the procedure, as i'm sure there is something special I will have to do to get the air out of the lines.
Old Jun 2, 2018 | 10:58 PM
sha4000's Avatar
sha4000
You can reuse the coolant.
Old Jun 4, 2018 | 06:05 AM
roadfrog's Avatar
roadfrog
Definitely.
Old Jun 4, 2018 | 08:01 PM
RNelson's Avatar
RNelson
Went to the dealer this afternoon, while it was on the lift they were showing me some things, I then asked about the hose, he took off the skid plate and you could see it perfectly, not one kink! It must be the angle or something. The hose was perfectly round, the tech said it was in perfect shape. Problem solved.... there was no problem.
Old Jun 5, 2018 | 08:09 AM
sha4000's Avatar
sha4000
It looked kinked to me also but I stand corrected. I have an LED light that I stick down in there when I can't see clearly.
OldLs400
Jul 20, 2018 08:14 PM
scRuss
Jan 23, 2015 03:03 PM
dhowat
Feb 4, 2014 05:27 PM
Och
Sep 22, 2011 10:27 AM
Blk04GS430
Oct 11, 2010 01:54 AM
