Ls 2007 460 air suspension issues
Old Feb 3, 2018 | 07:20 PM
Catt1964's Avatar
Catt1964
Smile
Well changed out the front air/suspension struts today and the car now drives completely different .....wow makes the car drive how it should, the old air strut on the left was quite soft to push up and down where the right side was totally different and bloody hard could not push it down at all. So very happy now no squeaking and spongy ride. Thanks everyone for your contribution.
Old Feb 3, 2018 | 07:54 PM
Falbz's Avatar
Falbz
So which air struts did you go with ?
Old Feb 3, 2018 | 11:31 PM
lsappsoc's Avatar
lsappsoc
yeah im curious too
Old Feb 3, 2018 | 11:56 PM
Catt1964's Avatar
Catt1964
PAO motoring was the manufacture but purchased through autopart-center on ebay no instructions but took me about 1.5 hrs on the first side then 1 hr on the right side, removing the airline was a bit tricky.
Jacked up the car and dropped out the top ball joints, removed the lower shock bolt and removed the top struts bolts, removed one of the connections to the sway bar a few brake line holding bolts with the strut loose could rotate the strut i could unclip the airline and remove the strut the right side was far quicker. Can't believe this made so much difference to the ride.
Old Feb 3, 2018 | 11:58 PM
Catt1964's Avatar
Catt1964
Also after changing them out the i had to start the car as there was no air in the shock, could not remove the jack until the shock was raised and inflated
Old Feb 5, 2018 | 01:17 PM
RA111724's Avatar
RA111724
Glad it worked out for you. You didn't have to do any dampening calibration or ride height adjustment with the Techstream software? That software is so nice to have.
Old Feb 5, 2018 | 11:07 PM
Catt1964's Avatar
Catt1964
Not at this stage, i did purchase the Mini-VCI but having issues loading it to the computer, one of the reasons I bought it so I could calibrate myself, my mechanic has one and last time after removing the tops of the air shock had to clear the fault.
Took it for its first night drive last night great lights and the ride is fantastic.
Old Sep 30, 2018 | 10:05 AM
Bryansoe's Avatar
Bryansoe
Default Is it still working ? I’m interested to change struts from them.
Hi, how’s the condition now? I’m interested to change my car struts from them. Thanks!
Old Oct 1, 2018 | 03:57 AM
Catt1964's Avatar
Catt1964
Pretty good, feels more car-like still have an adjustment to get right but a piece of mind no worry about air.
Old Oct 1, 2018 | 04:03 AM
Bryansoe's Avatar
Bryansoe
wow. Thank you! I’m going to replace all.
M3dicDO
Oct 1, 2020 02:00 PM
Spartan8
Mountain - Prairie
Nov 27, 2015 10:27 PM
jzqj55
Sep 28, 2015 08:52 AM
saustin
Apr 23, 2015 09:25 PM
Zodiac
Jul 19, 2014 01:01 AM
