‘13 LS 460 - wheel fitment inquiry - 275 for fronts?
Old Nov 30, 2017 | 11:40 AM
tofuprod's Avatar
tofuprod
Default ‘13 LS 460 - wheel fitment inquiry - 275 for fronts?
hi all-
I’ve searched around hard on the wheel and tire fitment thread with no look so turning to here-
simple question really.
Stock NON- f-sport. All wheel drive. No suspension mods
rim size: 20x10 front
offset: +38
tire size: 275/40/20 front
will this fit without rubbing and clearance issues?
Old Nov 30, 2017 | 12:17 PM
enoch861's Avatar
enoch861
You might have to go with a staggered setup depending on what you want. 275 might be a bit too wide in the front, I'm not sure of anyone running that wide up front, but the rear will happily take some pretty wide tires. There's people running 295's with no rub. There are also a few members that ran 305's in the rear.
Old Nov 30, 2017 | 01:25 PM
tofuprod's Avatar
tofuprod
thank you. Yes, I saw that 275 can fit with that setup without a problem. I should’ve have clarified, with it fitting in the front only in that same setup.
Will edit title. Please chime in.
Old Dec 3, 2017 | 08:06 AM
tofuprod's Avatar
tofuprod
Free Sunday Bump?
Old Dec 3, 2017 | 10:12 PM
Duck05's Avatar
Duck05
I have not seen or read anyone attempting to run 275s on the front of an LS...... 245 seems to be the standard (from the stock 235) ..... Staggered is the cleanest route...
Old Dec 4, 2017 | 11:28 AM
tofuprod's Avatar
tofuprod
ah I see.
reason I asked this was hoping to maintain a clean square setup (nothing too crazy) while maintaining the ability to rotate wheels/tires.
Old Dec 6, 2017 | 02:21 AM
Duck05's Avatar
Duck05
If those are your criteria then 245 all around seems to be the most popular setup...
Insedanity
Jun 16, 2016 10:27 AM
Cptfire441
Jan 21, 2016 03:13 PM
doodoo
Oct 14, 2013 12:16 PM
aldo23
Wheels, Tires & Brakes Forum
29
May 6, 2010 05:38 AM
SRV1
Mar 15, 2010 02:55 PM
