Warped rotor question
Old Apr 18, 2018 | 02:51 PM
Nospinzone's Avatar
Nospinzone
I should have added in my earlier post that there are better aftermarket rotors available. I still have my original rotors, but if I replaced them I would follow the advice here to use the Centric brand.
I will also endorse the Akebono ceramic pads. I have them on my car and my wife's Jag. Best brake pads I have ever had. Well let me qualify. There may be better braking pads out there, but neither my wife nor I track the LS or S-Type. What I love, love, love is the virtual non-existence of brake dust!
Old Apr 18, 2018 | 03:23 PM
213374U's Avatar
213374U
Originally Posted by yyymmm31
Based on the discussion on this forum, it seems that Centric Premium rotors and its Posi-Quiet pads proved to be a good choice.
Went with this setup in July of last year, roughly 15K miles ago, and my front left rotor is now warped. Not terribly, but it's enough to make noise and produce a little shimmy in the steering wheel when braking. Otherwise, no complaints. I'll likely just be ordering a single rotor to replace this one, not worth the hassle to have them turned.
And good info on torquing them down incorrectly, I'm wondering if this is my issue. I never pay attention to the order or how much I tighten them, but I always do it by hand and simply get them a hair past tight, so it's not like I'm putting a ton of force behind them. But, the car was in the shop for a bunch of front end work (differential) so maybe they could have done it with an impact, but I'd hope not given their reputation as one of the best independent Toyota/Lexus mechanics in N Austin. I'll be paying closer attention going forward.
Old Apr 18, 2018 | 09:11 PM
yyymmm31's Avatar
yyymmm31
Uneven torque on wheel lugs is one of the major causes for warped rotors. Other causes include washing your car (wheels) right after driving it or driving through water. In any case, following the torque specs and the right order of tightening up lugs helps reduce the risk of getting warped rotors. I have about 12K miles on my set of Centric rotors and pads without having problem. My main reason for replacing the OE rotors and pads with Centric brake components was for getting rid of the annoying brake pad/rotor noise when I pressed the brake pedal, not because of warped rotors.
Old Apr 20, 2018 | 09:07 PM
mckellyb's Avatar
mckellyb
Remarkably, I've yet to warp the EBC slotted rotors on my '08, and we just returned from a few days in Colorado which included a few fairly high-G, um, reductions in cruising speed.
The Yellowstuff pads are nicely aggressive but they do give off more dust than OEM.
On a semi-related note, I can say the 130 MPH governor kicks in remarkably gently and smoothly. Even with out-west elevated cruising speeds, MPG was 26+ on every tank, with 28.5, or so, on one of them.
I should clarify for those of you who have not driven on I-25 in Colorado...it's accepted the speed of traffic outside cities may be triple-digits. Even then, don't squat in the left lane. Instead, treat it like the Autobahn.
Old Jun 10, 2019 | 10:33 AM
DavidinCT's Avatar
DavidinCT
Originally Posted by roadfrog
Many of us went with Centric Premium rotors and couldn't be happier. They are awesome. I've had mine for a couple of years and they are still warp free.
Originally Posted by DavidinCT
In the same boat with OEM...will be ordering a set of those as well...
I was not impressed. After about 6 months the Centric Premium from Rockauto are warped again....they have been for a while now and I need to find a replacement again...
Anything reasonable priced that does not warp with a little heavy driving (I drive an hour each way to work and it involves traffic)?
Old Jun 10, 2019 | 03:03 PM
Originally Posted by FunFact
It seems many, if not all of you, seem to lack the understanding of what causes a rotor to pulse, so let me clarify this for you:
rotors can warp, but it takes either a physical strike to them or extreme heat. Which would be something like running full-pace at a track day until reaching brake fade points. Multiple times.
As you might imagine, this kind of heat doesn’t happen in daily driving, so you’re not warping rotors. What is happening is that your rotors are getting heated and eventually leaving deposits of brake pad material in spots, usually that may be a hot zone on the rotor. This buildup continues growing until you feel it pulse.
So, zero percent of you have warped rotors. You have pad deposits. A good way to prevent this is to bed in your brake pads with your new or resurfaced rotors. Here is a good basic method. There are also others, so don’t take this as gospel: https://brakeperformance.com/bedding-in-rotors.php
Why do you have to be so rude? This is a friendly, helpful community here and you consistently post in a rude and condescending way...
Old Jun 10, 2019 | 04:08 PM
jkittlesen's Avatar
jkittlesen
No doubt, rough childhood maybe?
Old Jun 10, 2019 | 04:10 PM
jkittlesen's Avatar
jkittlesen
Hey Fun fact..................
Many manufacturers require you to bed in brake pads after installation to ensure proper traction between the brake pad and rotor. This stop-and-go process, sometimes called “burnishing,” alters and usually increases the coefficient of friction between the rotor and pad to ensure stable braking power.
Despite the common use of this practice, however, not all brake pads require breaking in. Akebono’s ultra-premium ceramic disc brake pads do not require this step, because they are precision-engineered to perform and mold to your rotors over time. There is no specific burnishing procedure needed with Akebono brake pads.
When installing Akebono brake pads, technicians should follow all other procedures according to specification. Old rotors should be replaced or resurfaced, and the hub-mounting surface should be cleaned thoroughly and inspected for excessive run-out. Once Akebono’s brake pads have been installed, the job is complete and pads are ready for use—saving time and increasing bay utilization.
Trust Akebono quality to not only eliminate the extra steps and costs of bedding in, but to also ensure your customers stop safe-ly and smoothly every time.
Akebono manufactures 100 percent of its Pro-ACT®, EURO® and Performance® Ultra-Premium ceramic brake pads in the USA.
Old Jun 10, 2019 | 04:15 PM
jkittlesen's Avatar
jkittlesen
Fun you are in Texas, come on down to Round Rock, playing 18 tomorrow.
I'll buy you a few , smoke a cigar and relax.
Old Jun 10, 2019 | 04:28 PM
jkittlesen's Avatar
jkittlesen
Well that is one way of handling the situation!
Old Jun 10, 2019 | 04:31 PM
jkittlesen's Avatar
jkittlesen
I have come across rude sometimes yes, sorry for that but, I will get more civil.
After all it is just the Web! If we were talking face to face this would not transpire.
jkittlesen's Avatar
jkittlesen
Thumbs up
And a father that beat me and a mother that was never around. Haha.
No, my childhood was great. Plenty of working on vehicles, riding dirt bikes, going to great schools, and enjoying life.
Good deal!
Old Jun 10, 2019 | 04:33 PM
jkittlesen's Avatar
jkittlesen
I get whiskey bent and hell bound sometimes!
Old Jun 10, 2019 | 04:38 PM
The bottom line in the argument about warped rotors is semantics. Yes, the pulsating people feel that people attribute to "warped rotors" is caused by pad deposits on the rotor, not a physical warping of the rotors. However, the accepted description for the condition is "warped rotors" and rotors of different quality are more susceptible to warping than others (heat dissipation, compatibility with pad material, evenness and consistency of the rotor material, etc).
These cars with the OEM rotors have a tendency to develop "warped" rotors.
Old Jun 10, 2019 | 04:42 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Here is the rude and condescending comment just in case you can't pick it out.
If you’d like, I could show you that I can be truly condescending, but then you would be extremely upset seeing that you are being touchy with me delivering things in a matter-of-fact manner. If you don’t appreciate my delivery of knowledge, which far surpasses everyone’s on this forum, you can add me to your ignore list. How’s that for condescending?
If you think it’s rude, it’s because you took offense to it due to subjective interpretation of me being direct and to the point. There was nothing rude about it, as there are far harsher words I could have used if I wished to be rude. If you want sugar coating, you have the wrong person.
FunFact, please exit this thread.
Other folks, please knock off the personal comments.
