Did the conversion today and disappointed to say I am not happy with the outcome and am wondering if anyone has had or heard of any similar experience. or maybe can tell me if I just have higher expectations and this is what this product is like.
As you can see by the photos the car is SO MUCH lower to the ground on the front and when taken on a test drive to check the new struts the car was scraping off every speed bump as well as other imperfections.
Suncore is saying there is nothing wrong with what they sent me ..... they actually sent me a replacement that did not fix the issue. They agreed to accept them back and issue a refund but I am just very disappointed this did not work out as expected.
After reading that, and now your story, I'm confident I can go ahead and cross this one off the list for potential fixes if the air struts go on me. Another user here is piecing together his own conversion so hopefully that will go well, but the more I look around the more I'm inclined to simply replace the struts with OEM units when they finally go.
The air ride naturally seems to sit higher then springs, I had to manually change the ride settings through the sensors to get mine to sit properly
Can you please give us some details on how your conversion went? did you get any warning lights on the dash ?
How did your mechanic deal with that issue ? Thank you very much
The job itself went pretty easy.... its just a remove and replace type of thing. I did get the Height light on but its because I removed the actuators.... from a previous post I read here connecting those back should fix the issue. I removed the compressor relay to prevent it from working.
Regarding your comment of getting the KYB struts , I am thinking about going that route but the AWD air suspension is a little different as you can see if the first image. it requires a very hard to find part if it even exists in that form.
Thanks for the reply
BY actuators I'm assuming you mean the height sensors?
I have heard (even from suncore technician ) that the height sensors should be left in place to avoid any dash warning lights but its good to hear that it went smoothly.
Originally Posted by UZ214
I am thinking going the exact same route ; please share your experience/ feedback on the ride quality once you have then on
I will make a thread on it forsure, I have all the parts ( I think ) , struts, springs and strut mounts .....not sure if anything else is needed
If anyone can think of anything please let me know
