So the other day somebody backed into the front drivers side quarter panel and left a decent size dent over top of the tire. I'm getting it fixed but also the trac light came on and won't go off. Any ideas on what the issue is? (2013 Lexus LS 460 w/AWD)
What's a trac light? And if it stays on, maybe the wiring was damage and it is has a continuous ground path...
Traction control light is what he means.
So, no Trac till it's fixed. You could pull the battery for 15 of so, and see if it resets (or if you have a Techstream laptop setup, you can possably get more info on it or just reset it) and then see if it comes back on.
If a code is coming up, you should see if you can get the code number to see what the issue is.
