Trac light is on
Old Mar 2, 2004 | 06:22 PM
lexsc3's Avatar
lexsc3
Default Trac light is on
my trac light has been coming on a couple time in the pass couple weeks.....Its the trac light on the speedometer, not the trac light next to the engine check light......It stays on while the engine is one but once i turn off the engine it goes away and doesnt come back for a week or so......Anyone know what it is?
Old Mar 2, 2004 | 07:26 PM
Carbon J's Avatar
Carbon J
Post
Do a search, many questions and answers on this topic. Also check for a failure code, could be a oxygen sensor.
Old Mar 2, 2004 | 07:46 PM
lexsc3's Avatar
lexsc3
already did a search couldnt find anything with the trac light on the speedometer, only stuff with the trac light next to the engine check light
Old Mar 2, 2004 | 08:44 PM
andytseng's Avatar
andytseng
has it been raining, and have you been driving all krazy in the rain?
just a thought
Old Mar 3, 2004 | 10:56 AM
lexsc3's Avatar
lexsc3
i mean the light comes on when the traction control is on but thats only for a couple secs.....the light comes on and stays on, it was perfectly drive yesterday
Old Mar 4, 2004 | 09:32 AM
Nick T's Avatar
Nick T
lexsc3,
Pull and post your codes. If you do not have the service manual, a search here should turn up directions on how to pull your codes ( my brother VQT posted it sometime ago ), Not sure if the SC300 has the same codes as an SC400 but if it's an ABS code 43 and Trac code 54 it's most probably a failed Trac High pressure hose,
Regards
Old Mar 6, 2004 | 07:13 PM
nextlevelcoupe's Avatar
nextlevelcoupe
i've started out having this same problem and it turned out into this problem for me(which occasionally doesn't happen): https://www.clublexus.com/forums/sho...hreadid=111708
Old Mar 10, 2004 | 11:37 AM
lexsc3's Avatar
lexsc3
i pulled the codes, the ABS is 54 and the Trac is 43....anyone can tell me what this is?
Old Mar 10, 2004 | 11:57 AM
lexsc3's Avatar
lexsc3
i looked at the high pressure hose and its leaking, does anyone know the part number for it?
Old Mar 18, 2004 | 01:23 PM
lexsc3's Avatar
lexsc3
i replaced the high pressure hose today.....it took me all of 15 mins at most....bleed the system after and the brake feel is much better and the traction control doesnt come on at random times.
Old Apr 9, 2004 | 08:40 PM
lexsc3's Avatar
lexsc3
the light is back again, anyone have any suggestions on what it could be?
Old Apr 13, 2004 | 01:56 PM
lexsc3's Avatar
lexsc3
could the moderator move this to a better section so i might get some of my questions answered....
Old Apr 15, 2004 | 12:17 AM
bishop977's Avatar
bishop977
Default a little off topic
i have a trac light problem too. i noticed it came on only when i push the car, when i floor it. then it goes on. once i let go of the gas it disappear . ever since then i don't floor my car ne more.
Old Apr 15, 2004 | 02:17 PM
lexsc3's Avatar
lexsc3
thats the traction control kicking in, its normal.......mine light is staying on untill i turn off the car, its a problem with something in the traction control system but i dont know what, i thought i fixed it with the high pressure hose but now i get a high pitch noise that sounds like something i choking and usually twice and then the light comes on.....if anyone know what this is and can help.....i might end up bleeding the whole system and see if that fixs it
Old Apr 5, 2011 | 06:24 AM
BobbyB's Avatar
BobbyB
Default Trac Problem
I know this is an old post, but did you ever find out what the problem was..?
I have the same problem. I know immediately when the light comes on, because the car drive changes so much....thanks.
mechanChic
Oct 17, 2012 10:32 PM
Vampire222
Sep 18, 2011 11:56 PM
chriswins
Aug 20, 2009 05:27 PM
plugmaster
Oct 12, 2005 04:11 PM
jcart05
Jun 16, 2004 09:35 AM
