LS460 PCV Valve Location
Old Feb 14, 2019 | 11:20 PM
jdanielca's Avatar
jdanielca
Originally Posted by roadfrog
Im doing my fuel gasket recall next week (17th). Im gonna inquire about this.
we have a fuel gasket recall? ELF ? Fuel pressure sensor? Anyone knows if this is the same as fuel pump gaskets?
so they are telling me it is going to take one week. For all 3 recalls to be done.
Old Mar 17, 2019 | 11:15 PM
elejes's Avatar
elejes
Originally Posted by robert1408
LS 460 PCV valve is under the intake manifold. Alldata shows 2.1 hours to change it. Some coolant has to be drained, the entire air filter and inlets are removed. Then the injector drivers and wiring harness are removed, followed by removing the intake manifold. The PCV valve is then accessible. It's not far from the oil filler, down in the valley.
so access is through the bottom not the top of the engine bay?
Old Mar 18, 2019 | 04:51 AM
johnnyg66's Avatar
johnnyg66
Nope from the top. Good luck.
Old Mar 18, 2019 | 04:52 AM
johnnyg66's Avatar
johnnyg66
Nope not the same. But i would guess they are messed with too. I think there is a long you tube video showing the ELF process. Made by a Lexus dealer.
Old Mar 18, 2019 | 09:54 AM
ALK's Avatar
ALK
I will be replacing the pcv valve later this week and will report back .
Old Mar 18, 2019 | 10:30 AM
elejes's Avatar
elejes
please keep us posted. I would like to replace mine too.
Old Mar 18, 2019 | 10:32 AM
ALK's Avatar
ALK
for sure. My LS is 240.000 miles . I will replace the seals of the intake and cleaning the throttle body .
Old Mar 18, 2019 | 10:36 AM
elejes's Avatar
elejes
have ever replaced the drivers side valve cover seal? I did the passangers side this last weekend and it was a pain to reposition it because of the angle it slides in and sits. I didn’t want to risk going through the same on the drivers side.
I also replaced both fuel injector seals that were leaking. Those were easy.
Old Mar 18, 2019 | 10:39 AM
ALK's Avatar
ALK
I did the driver side with a freind . The problem is that you have to remove the high pressure fuel line in order to remove the valve cover.
Old Mar 18, 2019 | 05:23 PM
elejes's Avatar
elejes
any pics of the location?
Old Mar 19, 2019 | 03:43 AM
ALK's Avatar
ALK
This should help .
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Mar 21, 2019 | 08:28 PM
elejes's Avatar
elejes
This should help .
Thanks for the help. I will put the pcv project on hold for now.
Old Mar 21, 2019 | 10:51 PM
diamente's Avatar
diamente
I paid for toyota 3 day access to techinfo but I was sick and couldn't download the whole repair manual. I would be appreciated if you can give me a link to download. My e-mail is goodarticles@yahoo.com thanks.
Old Jul 7, 2019 | 07:31 PM
Brainez's Avatar
Brainez
Default How to change the pcv if anyone is still wondering
Old Jul 9, 2019 | 10:59 AM
elejes's Avatar
elejes
So I don't have to remove the fuel injectors? That's good, I guess I can give it a try. I'll order a intake seal while at it.
thanks!
