interior rubbing noise over bumps. fix?
In the attached image, I circled an area in red. When going over bumps, I hear a soft but annoying rubbing noise.
Any clue how to fix this?
*image is taken from the drive side rear seat.*
is that great that you isolated that part the next step to do is what was stated in the above post... the only I think I hear is the my wheel lock rolling around. I need to find a different spot..
my dealer tosses it into the rear spare tire area -- there's a little cubby sized perfectly for that in the spare tire carrier
From: Vancouver Island, BC -ex Illinois &Toronto, ON
Maybe the case with the 460 too now?
edarte,
a few times while driving, i've reached back there and forced my fingers between the door trim and pillar
(real fun). doing this stopped the noise. this morning i was trying to figure out how to get some foam tape into the problem area.
grabbed two different sizes of this stuff at home depot.
There is a TSB out there for the 600s..involves new heavy duty clips on the firewall behind dash along with foam to secure dash..I think its thicker foam..cant tell you exact type used. I do know its major surgery involving dash to be disassembled to access behind it where the fix is
I was wrong about the rubbing area.
It's where the driver door meets the door frame.
Opposite side of where I circled in red.
In the past month, I've driven this car once, so I haven't messed with fixing it.
