CD tracking does not work
Old Mar 4, 2010 | 04:40 PM
june's Avatar
june
Default CD tracking does not work
I have '07 LS460 (16k mi). Has anyone experienced any problems with the Tracking buttom on the CD player? When we listen to a CD and want to change the track, for example from track 3 to 4, or track 3 to 2 it does not change.
Any help is appreciated.
TY June
Old Mar 4, 2010 | 05:31 PM
jlawr's Avatar
jlawr
Check with a Lexus Dealer. Sounds (NPI) like your car is still under warranty.
Old Mar 5, 2010 | 12:47 PM
KeysRx300's Avatar
KeysRx300
Default C/D Track
Is it doing it with both the radio button and the steering wheel button? Just C/Ds or does it happen with SAT or Radios?
Old Mar 5, 2010 | 02:02 PM
jmcraney's Avatar
jmcraney
TY June
I have been hesitant to tell you this, but just in case you don't know. When changing to a lower track, you must hit the "down track" twice to get to the next lower track. If you want to go to a lower track you must hit the "down track" twice, quickly. The first time you hit the "down track" it takes you to the beginning of the current track and then you have a short window to hit it again to go down one track. The "up track" should advance one track up for each switch operation. I hope this helps.
Old Mar 6, 2010 | 06:17 PM
june's Avatar
june
Thanks JMCraney you are correct, it both works, the radio and the wheel button, just hit it twice.
Thanks for the input.
June
Old Mar 9, 2010 | 05:33 AM
jmcraney's Avatar
jmcraney
June,
Glad your problem is resolved. I was hesitant to tell you about the down-track oddity because your description didn't exactly fit that and I didn't want to add confusion. Having to hit the down-track twice to go down is a common characteristic of most CD players. The first time I encountered that it was very perplexing to me.
Old Mar 10, 2010 | 06:50 PM
june's Avatar
june
Thanks again for your input JMCraney. I usually just listen to the whole CD! I've never had to change the track before.
Thanks,
June
Arbitrage1
Sep 14, 2008 03:22 PM
OutCaster
Jun 4, 2008 08:51 AM
dannygjatt
Mar 7, 2008 02:43 PM
cowabunga
GX - 1st Gen (2003-2009)
Mar 2, 2006 01:42 PM
markberry
Jan 17, 2006 09:11 AM
