engine sounds loud need help
Old Oct 2, 2008 | 01:42 PM
jessejames's Avatar
jessejames
Default engine sounds loud need help
I have the ls460l touring,and when i am driving the engine sounds very loud, and also at traffic lights i thought this car was quiet. Is this normal?
Old Oct 2, 2008 | 02:32 PM
CEOEngr's Avatar
CEOEngr
If it is that I strongly suggest visiting the dealer ASAP and have it checked out. There has been a few reported instances of engine being loud and rough. It turned out be damaged valves and the rocker arms (?).
Old Oct 2, 2008 | 04:05 PM
Whipple1's Avatar
Whipple1
How long did you own the car?,Did it always sound the same,or did it recently get loud?Maybe there is something wrong,I can hear my motor slightly when stopped with everthing off (radio/AC/heat),But I wouldnt call it loud.In the beginning I actually walked away from the car a few times and left it running thinking I shut it off .If your that concerned bring it to the dealer and have them check it out,or compare it to another LS
Old Oct 2, 2008 | 04:38 PM
CEOEngr's Avatar
CEOEngr
Read the the thread linked below; I hope yours is not in the same category.
https://www.clublexus.com/forums/sho...e+noise&page=2
Old Oct 5, 2008 | 06:27 PM
boxcarfan's Avatar
boxcarfan
theres a TSB to replace 2 pullys on the car...there made out of plastic and come apart, the new ones are metal
Old Oct 5, 2008 | 06:59 PM
VIS250P's Avatar
VIS250P
I believe the TSB of 2 pullys because they will make the motor shaking and possible make loud noise..
Old Oct 5, 2008 | 07:31 PM
boxcarfan's Avatar
boxcarfan
im not sure about that one...but i know they do come apart...the smaller pulley i found just shattered lol. that was only 1 time, ive done like 15 of them...i can do it in like 10 mins tops lol. but yea thats why the new ones are metal lol.
but maybe this guys has come apart and is makin a shakin lol
Old Oct 7, 2008 | 07:50 PM
mduffin's Avatar
mduffin
Default LS engine noise
I complained of engine noise in my '07 LS460L even after TSB for defective pulley was performed. Generally I would hear engine noise when the HVAC was off (spring and fall of the year).
Turns out the noise is from the fuel system & lack of sound insulation. The dealer demonstrated the noise was "normal" by having me sit in other new LS460s running at idle. I was told the engine noise was a combination of:
1. Direct injection system uses a cam with a very large lobe which causes a noticable cyclical sound as the cam operates the pump. Sounds a bit like a diesel truck engine to me.
2. Less sound deadening is used (compared to previous three generations of LS) to transfer more engine sound to the passenger compartment in an attempt to compete with BMW. On hard acceleration the engine does sound better than previous LS generations but pales when compared to BMW and Audi. At idle though it sounds terrible.
This is my fourth LS (1990, 1997, 2001 & 2007) and by far the loudest. I want a return to the quiet days of the past. The LS historically was well regarded for its quiet interior. I think Lexus corporate/design is afraid of their shadow(s). Will creating a noisy cabin really help the LS compete? It's not working for me.
Old Oct 7, 2008 | 08:12 PM
boxcarfan's Avatar
boxcarfan
well another reason is that the crank and cams are ran off of chain instead of a belt like all past engines. and the a/c compressor doesnt have a clutch on it...so that must mean that they control the orifice before the evaporator...but the compressor is always turning lol.
IMO...the new GR motors are crap lol...theres TSB for the 3.5L with direct injection with the fuel tubes that run across the valley..and the LS has a even has a TSB for replacing cylinder heads...and on the 3.5L again there is a TSB for the VVT-I...which i have seen done...omg what a PITA that is! just hope the GR motors wont be as bad as the RX330 everything went wrong on the RX330 lol.
Old Oct 8, 2008 | 04:51 AM
jmcraney's Avatar
jmcraney
You need to read the "Wind Noise Fix" thread and you will understand that, in many cases, the wind noise and poor sound isolation are part of the same problem. It is related to the triangle shaped trim at the front corners of the windows in the front doors. There is an easy, inexpensive fix. I suspect that this defect has caused Lexus to have many complaints about wind noise, brake noise and engine noise. In most cases the 2007 and 2008 LS460s and LS600s are as quiet as any cars Lexus has ever made after you get that defect fixed.
Old Oct 8, 2008 | 09:36 AM
jmcraney's Avatar
jmcraney
mduffin,
Please don't take offense at what I am about to say, I understand that you are sharing information that the dealer told you.
The idea that the poor sound isolation is "by design" sounds ridiculous to me. It sounds like a "sister story" to the wind noise issue that goes something like: "The reason that you hear the wind noise is because the car is so quiet." These are things that they tell you when they are out of ideas and solutions or when they think you are imaging this stuff. I think that these stories are made up at the dealerships. After I fixed my car it is exceptionally quiet. I bet my car was built in Japan by the same robots that built all the other cars.
I think if Lexus thought that "engine noise" inside the car was important, they are good enough technologist to put a microphone or microphones around the engine and exhaust to capture the sounds and project them through the ML sound system. Then those who wanted to hear it could turn it up until it knocked the windows out and the rest of us could turn it off.
Does anyone think that Lexus would let noise in intentionally? This is not a rhetorical question.
Last edited by jmcraney; Oct 10, 2008 at 03:10 PM. Reason: added additional comment
Old Oct 9, 2008 | 09:49 AM
garyr's Avatar
garyr
Before I had the windnoise fix my car sounded like I was driving with the windows open. I could hear everythingout side, other cars, road noise from the tires etc.
When you remove the plastic triganle there are 2 large rectagle holes that the clips go into. Those holes also alow noise to come right on the cabin. Jeff's fix also seals those holes and seals out the noise.
After Jeff's fix it sounded like a diffrent car. The car is now quiet. The car was built extremly quiet but they defibatly screwed up on the trangle peice.
Jjmuckley
Feb 17, 2022 06:32 AM
johnc2
Jul 21, 2010 03:41 PM
callumm
GX - 1st Gen (2003-2009)
Aug 2, 2009 02:06 PM
shinbrianj
Mar 4, 2008 10:20 PM
JamesN
Jun 29, 2003 10:48 AM
