A/C issue
Old Dec 23, 2006 | 07:10 PM
jotafl's Avatar
jotafl
Question A/C issue
I am having a little problem with the "Auto" air circulating feature on the LS460. On my LS430 once you press the air circulating feature and the "Auto" lighted up, that feature will stay on even when you turn the A/C or engine off. On the LS460 I noticed that when you press the air circulating feature until you get the "Auto". Ifd you turn the engine off, when you turn the engine on again that feature is recycled and then you have to press until you get the "Auto" lighted up again.
As I said, on the LS430 once you did it once no matter what the feature will stay on even if the engine was turned off and on.
Anyone having the same issue, care about it, or knows how to enable that option and leave it on Auto even if the engine is turned off?
Txs
Old Dec 24, 2006 | 04:27 PM
spwolf's Avatar
spwolf
your post is not clear, but you can turn off recicycle at startup feature at dealer...
Old Dec 24, 2006 | 05:22 PM
spwolf - he means why does the 'auto' on setting get lost every time the car is restarted? It certainly stayed on in the RX and GS I've owned.
Old Dec 24, 2006 | 06:31 PM
Luxofreak's Avatar
Luxofreak
As far as I know the features you choose are kept even when you turn off the engine and turn it on again next day for example. The fact that the LED on the air circulating mode isn't on the Auto doesn't mean it won't change to outside air / inside circulation.
Also, when you turn off the engine with the A/C on Auto, at least on my car when I turn the engine on again the Auto function is still selected. Of course the A/C will only kick in after the engine is warmed up again.
Old Dec 24, 2006 | 07:53 PM
jotafl's Avatar
jotafl
Exactly like that bitkahuna, maybe I should have used the recycle instead of the circulating. When on Auto the A/C will select for you when to turn the recycle on or off depending on conditions of the outside air. That is the feature that I am talking about. On the LS430 if you left it on Auto mode, no matter if you turn the engine off for the day and the next day will start the engine again and the A/C on, then the Auto would be selected already. Now I have to select the Auto feature every time I turn the car on.
If this is still confusing let me know and I will find a way to explain it better. Thanks.
Old Dec 24, 2006 | 10:21 PM
And he's not talking about automatic temperature control, he's talking about auto for the recirc. The recirc button cycles (at least it did on my old GS) from outside air, inside air, auto, etc.
alexwest
Sep 25, 2016 05:04 AM
lexuspete
Oct 1, 2015 08:42 PM
sas
Oct 29, 2006 10:47 PM
joeyGS430
Jun 30, 2001 10:41 PM
