Puzzling door lock actuator issue
Silly question, is your trunk light working? I had a similar issue:
https://www.clublexus.com/forums/ls-...or-issues.html
The solution was a fuse in the trunk that also controlled the trunk light.
yep, both trunk lights aren’t working. Tried new bulbs but nada. So you just replaced that fuse and the door lock started working again 100% of the time? I took a look at your thread, but there’s not any other information offered so I thought I’d ask. Any thing else you can tell me about it? I’ve spent probably 20+ hours trying to figure out the issue but am still scratching my head. Because with mine, all of the fuses in the trunk checked out. I pulled and visually inspected them at first hoping that would be it (I seem to never have the kind of luck that results in easy fixes being the solution when I have a problem like this.) I then checked all fuses in other 3 boxes (except for a handful in the box under passenger side dash), all looked perfectly intact. So I then went back and rechecked them all again using my multimeter this time. Still haven’t found any blown fuses. I may as well just pull the fuse that covers the trunk lights and put in a new one just to be safe. Maybe it’s the slightest hairline fracture in that fuse that’s just big enough to disrupt functionality but not big enough to show up on my meter. I don’t even know if that’s possible but I’m out of ideas.
I had the door panel off of the door with the lock that I’m having trouble with last night, and spent a ton of time inspecting all the wire bundles, connections, door control module, actuator, etc. Everything looks OK from what I could see so for now I’m biting the bullet and plan to take it to dealer Monday.
Kills me a little inside as I’ve already invested at least 30 hours trying to figure this out on my own and save some coin. Not to mention the satisfaction you get when you finally solve a mystery like this. For me there’s few things that feel better in life.
It was the fuse panel on the driver's side of the trunk. I don't remember which fuse # but a quick look online shows #8 in the trunk, driver's side. It was one of those, I would check them all again, couldn't hurt and might solve your issue.
[img alt="Fuse box lid from fuse box located in luggage compartment, on driver’s side right next to the trunk lid automatic opener/closer motor. Trying to determine, which of these, if any, controls the two “194” style interior trunk lights.
"]https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/1500x2000/img_6646_4793931dbfe7f3b6a064b1b6475d86c69ddd9623.jpeg[/img]
now I just need to figure out what’s the deal with starting the car. Oh and I need to verify the trunk interior lights now work, which I’m guessing they will. Just picked up some new bulbs so we shall see. So happy to have the trunk and door lock issues resolved after all the time I put into those
. Saved me a few grand from what I would’ve been charged by dealer or even my independent Lexus mechanic, who I’ve lost confidence amd trust in seeing how he told me the door needed a new actuator when in reality it was just a disconnected harness that he should’ve been able to identify and find if his own customer was able to.
ljCharlie
Aug 28, 2025 01:27 PM
