Brake warning light flashes
Old May 11, 2025 | 01:20 PM
Bigguy818's Avatar
Bigguy818
Default Brake warning light flashes
I have noticed this brake light flashes in and off and I noticed it when turning it stays on longer when im at a stop. Did any one had this happen to them before.
Old May 11, 2025 | 04:36 PM
Gerf's Avatar
Gerf
Ive never seen a brake light in that area with just the key on when most of the warning lights are displayed so I'd say check your brake fluid reservoir level.
Old May 11, 2025 | 04:51 PM
Bigguy818's Avatar
Bigguy818
I have checked the fluid and it’s right at the minimum mark, that said brake fluid doesn’t go low unless the pads are wearing or I have a leak.
no leaks were found and I will take it to have my rear brakes checked as I think they are due, the fronts pads and rotors were replaced last year.
Old May 11, 2025 | 11:45 PM
According to the manual that's the low fluid warning
Old May 12, 2025 | 05:22 AM
Bigguy818's Avatar
Bigguy818
To my understanding, brake fluid shouldn’t get low unless there is a leak or the brake pads are wearing is that correct?
Old May 12, 2025 | 08:07 AM
Gerf's Avatar
Gerf
If you had a leak you'd have no brakes by now, as the pads wear the fluid level will go down.
Old May 13, 2025 | 12:18 AM
Yes, the system will also SCREAM if it senses an actual leak. You likely are just low from service related level adjustments but a quick check is a good idea if there is any doubt. The lazy way is to just stoke the pedal like 15-20 times and see if the level moves at all, more involved way is to inspect the brake system
1fast
Jul 3, 2024 02:55 PM
Farino81
Feb 19, 2012 04:52 PM
techsc400
Jun 15, 2009 03:39 PM
uplusd
Apr 5, 2007 10:06 PM
ES300SD
Mar 4, 2002 11:23 AM
