Engine Oil Consumption
Old Nov 26, 2024 | 10:21 AM
farelex's Avatar
farelex
i keep checking it every week and just today i had checked it , it shows above the low mark by little ( that mean it still consuming oil)
and i the cat is done around 2750 KM ( 1718Mi) when i had replaced the oil , i think this is abnormal consumption
Old Nov 26, 2024 | 10:23 AM
farelex's Avatar
farelex
i always used Genuine Lexus Motor oil only that certified by Lexus dealer
Old Nov 26, 2024 | 10:28 AM
farelex's Avatar
farelex
thanks marc for the advice , i will try it , i ahd chekced the service history of the car i had found the last service was recorded on 40K mi
Old Nov 26, 2024 | 10:32 AM
farelex's Avatar
farelex
thanks striker 223 for the advice
i will try it and cross fingers ,
Old Nov 26, 2024 | 10:35 AM
farelex's Avatar
farelex
this is striker 223 ?
Old Nov 26, 2024 | 02:29 PM
Gerf's Avatar
Gerf
So, if I use this stuff does it clean my fuel filter also?
Old Nov 26, 2024 | 02:53 PM
Probably not lol!
Yes use that, it breaks up the carbon well without venturing into tbt ultra aggressive type of treatments
Old Nov 27, 2024 | 02:43 PM
sktn77a's Avatar
sktn77a
Before you add any of these snake oil treatments, add 1/2 qt of oil (and a second if necessary) and note the oil level. Check it every 100 miles. These cars usually don't burn any oil between oil changes.
Old Nov 28, 2024 | 02:03 AM
It's not being added to oil, it's being added directly to the combustion chamber via spark plug holes.
You then leave it for 4 hours per 90* of engine rotation to let it try and soften the carbon locking the rings up. B12 is a moderately strong solvent that won't cause to LS y issues even if you are stupid with it unlike some of the serious solvents. That's why I suggested it, I've had it work many times in many brands engines without having to run the risk of the strong stuff.
Old Nov 28, 2024 | 04:27 PM
sktn77a's Avatar
sktn77a
The oil I was referring to was the snake oil!
I wouldn't have thought an LS engine with only 80k miles on it would need cylinder decarbonization(?) In the old day, we used 2 stroke oil to accomplish the same thing. Don't know if it actually did anything but that was the conventional wisdom in the 1960s.
liweil
HS 250h Model (2010-2012)
15
Sep 2, 2023 01:47 PM
bryan11
Aug 5, 2021 04:00 PM
mrbuddy
Feb 21, 2020 07:18 AM
jadachriss
Nov 27, 2019 03:42 AM
Arein
IS F (2008-2014)
Nov 15, 2019 07:08 PM
