Low oil
Old Sep 2, 2019 | 12:34 AM
Arein's Avatar
Arein
Default Low oil
Few weeks ago, after stopping the car (2010), low oil notification appeared. I check the oil from time to time, and didn't notice it dropping down, so that was a complete surprise.
I checked the dipstick and it was empty. Had to add 1 liter so it would be in between low and high (checked new level 5 mins after stopping the engine).
Until now the car didn't burn oil, maybe topping it off max 1 liter between changes.
When changing the LCA bushing few weeks ago, was told that the rear crankshaft seal might need to be changed.
Any ideas how to investigate what might be the issue. Can OBD show the exact oil level, I am thinking to check different driving scenarios and checking the level with OBD.
Old Sep 2, 2019 | 06:26 AM
Jwconeil's Avatar
Jwconeil
First step is to thoroughly investigate for a leak. If you need a rear seal, that is most likely the issue. Then you have to decide if you want to keep adding oil or get it repaired. I recommend repair.
If it’s burning oil, that is a more difficult issue, and I will let the smarter members comment on next steps. How many miles does it have?
Old Sep 2, 2019 | 09:21 AM
Arein's Avatar
Arein
It has 66k miles. I pushed it a bit a while ago with some donuts and some drag racing. Checked the oil after, and it was unchanged.
There is some white smoke when starting up, have to check if it's vapor or burned oil.
Old Sep 2, 2019 | 01:41 PM
newgsman's Avatar
newgsman
White smoke is vapor. Blue smoke is oil. I would just monitor the oil level for a couple of months and see if it is burning consistently. Sometimes these engines will consume more oil if driving really hard ( drags, donuts, etc.) If normal driving is not effecting the oil consumption you're probably good to go.
Not sure if too many people have experienced rear main seal leaks. 66k miles is not a lot of mileage. Did the car sit for an extended period of time?
Old Sep 3, 2019 | 02:56 AM
Arein's Avatar
Arein
Yes, it must have sat for some good time. I bought it not long ago so I don't know details, but I guess it could be ~1 year.
The smoke must have been vapor, I started a few times after letting the car sit, and there was no smoke.
Old Sep 3, 2019 | 06:17 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
If you want to be unquestionably certain, have a leak down test done. If it passes a leak down test and you have no external leaks, something else happened, but you're very unlikely to be burning oil. No blue smoke is usually a good sign, but if you have cats, they can clean up a surprising amount of hydrocarbons in the exhaust before they start blowing out clouds of blue.
If nothing else, monitor the oil level carefully.
Old Sep 6, 2019 | 12:07 AM
Arein's Avatar
Arein
Will get back to this thread after some time monitoring the oil level. Thanks guys!
Old Nov 13, 2019 | 11:38 PM
Arein's Avatar
Arein
So it was one of those strange occurrences that happens only once. Didn't have any more issues with the oil level.
Old Nov 15, 2019 | 04:31 PM
2010ISF's Avatar
2010ISF
I get this notification on my car all the time but it only happens when I'm sitting there idling for a few minutes. I'll drive to work and get there like 20 minutes early and sit in my car and rock out to music before I go in and always after a few minutes of idling the notification comes up and then goes away after like 10 seconds. I check the oil here and there to make sure everything is good and the car isn't burning any oil so I figured its just a weird bug that happens now that my car has 120k miles
Old Nov 15, 2019 | 07:08 PM
av8or's Avatar
av8or
Just got my rear main seal done two days ago. $1600 labor, parts $47
mrbuddy
Feb 21, 2020 07:18 AM
GREED777
IS F (2008-2014)
37
Sep 20, 2017 03:02 PM
Conant
Maintenance
Mar 25, 2017 07:14 AM
flektone
Jun 27, 2014 09:37 AM
mandyfig
Nov 19, 2013 10:35 AM
