Trunk Strip
Old Mar 2, 2024 | 05:12 PM
RandyV's Avatar
RandyV
Default Trunk Strip
I recently had some work done on the trunk lid and it seems to not be in proper alignment now. After being in the rain for a few hours I had water intrusion and water collection in the spare tire well.
Is the black plastic trunk edge strip supposed to be above or below the rubber gasket? See pics of current configuration.
Any other thoughts on how to properly align the trunk liD to eliminate leaks? Thanks.
Old Mar 3, 2024 | 12:16 AM
BB9's Avatar
BB9
That plastic piece supposed to be tucked under the rubber seal. Also, it is not clear on your picture but I think that metal loop that trunk lock engages on is sticking out too much. What kind of work did you do in the trunk? Did you do anything with the lid or the lock? Here's how it looks on my car.
Old Mar 3, 2024 | 09:05 AM
Gerf's Avatar
Gerf
Something is wrong with that plastic trim by the seal.
Old Mar 3, 2024 | 01:40 PM
RandyV's Avatar
RandyV
Much thanks gents - this explains why the boot releases with a loud POP and why the trunk is not seating against the seal properly! The car was rear-ended requiring the entire trunk assembly to need removed, body work done, and the trunk reinstalled.
Looking at your pictures it appears the plastic piece just lays down tight against the rubber seal, as opposed to the plastic piece being below the seal? Is that correct?
Any tips on removing that plastic strip or is it fairly straightforward when looking at it closely?
Old May 26, 2024 | 12:36 PM
RandyV's Avatar
RandyV
I'm still tryingto figure out how to adjust the alignment on my trunk.
The right side rides higher with a wider gap than the left side. The latch seems to sit low.
Any thoughts?
Old May 26, 2024 | 03:33 PM
Anfanger's Avatar
Anfanger
You likely need to adjust the right hinge.
Old May 27, 2024 | 10:25 AM
Nagman's Avatar
Nagman
I have the same issue on my 2014. Do you have any info on how to make an adjustment?
Old May 27, 2024 | 03:50 PM
Anfanger's Avatar
Anfanger
I couldn't find any information in the manufacture repair manual. There is information how to adjust the trunk horizontally and the lock but not vertically (trunk). Before messing with any adjustments, make sure that the seal is seated properly. If that does not help, you can start with removing the trunk lining and checking for adjustment bolts/nuts.
Old May 28, 2024 | 04:10 PM
RandyV's Avatar
RandyV
Yes, indeed. Looking for advice on HOW to adjust it.
Old Jun 3, 2024 | 12:18 PM
Nagman's Avatar
Nagman
Ok Thank you!
boz151
Jun 7, 2019 08:53 AM
bigsherv
Feb 22, 2018 09:19 PM
CrazyChino
NX - 1st Gen (2015-2021)
Apr 26, 2017 03:25 PM
yardie876
Aug 5, 2014 09:44 PM
Truc
Apr 27, 2002 02:33 AM
