What's not wrong with your LS
Now my second journey begins. 2017 460 bought at auction after hail damage with 78K. Interior is clean. Only error on dash was key Fob battery replacement. Just replaced front and rear brake pads yesterday. Car drive much better than my 07 460 and interior is more updated.
So I finally concluded my minimum guidelines were:
-It ought to have less than 100K on the odometer,
-2015 and newer.
- No air suspension.
I figured the added weight and complexity of an air suspension system, that so many owners seem to have expensive problems with, could not be worth the trade-off of lowered durability + being expensive to repair.
- Rear wheel drive only (as for air suspension).
- No hybrids -
Eventually wound up paying $36,500 for a 2017 Lexus LS460 w/ 69,500 miles because I was already smitten it with by the end of the test drive (this car has no air suspension, and is rear wheel drive only).
I anticipate you will get a great deal of satisfaction from owning an LS. It is Lexus' so-called "flagship" and as such it is one of the finest examples of excellence in automotive engineering on 4 wheels.
Dennis
My LS now has 304xxx miles and drinks oil. Its gotten so bad that i wait for the car to tell me to add oil. It's burning a quart every 500 miles. I feel if I top off the oil it just burns or leaks it faster. Considering I've spent nearly $20k on this car, replacing the motor would be cheap. I've stated before if I we're to replace the motor it wouldn't be the 1UR-FSE but of course I know putting another motor that is not the original would cost me a lot more money. I'm looking into just buying new high friction piston rings and taking it to a company that specializes in rebuilding these motors and have It back in less than a week. So when I do replace the motor I know my LS will last another 250xxx miles with no problems, except fluid changes.
At the beginning didn't realize these older models would be such money pits, compared to the 2013 and later models which were built with revised parts and have better quality and reliability than the earlier models. So whoever reads this DONT buy pre 2012 ONLY buy post 2013 LS460s and you will have no issue's...for the most part if you stick with the service intervals.
I have always taking the car to have the maintenance done on it at its scheduled times. The only thing good about the car is it looks good. Also the dash and interior panels were replaced a couple years ago under the recall. Dealer billed Lexus over 8500 to replace. The car only has about 135k on it. What an expensive POS. Also by the way the oring seals on the oil filter housing are leaking and they need to be changed, I can do that myself thank goodness. I will never buy another one!
I also know of two people who own one are both have the ABS VSC warning on their dash
-2015 and newer.
- No hybrids...
Eventually wound up paying $36,500 for a 2017 Lexus LS460, that I was smitten with by the end of the test drive (this car has no air suspension, and is rear wheel drive only).
I anticipate you will get a great deal of satisfaction from owning an LS. It is Lexus' so-called "flagship" and as such it is one of the finest example of automotive engineering on 4 wheels.
Are there any on here with a 13-17 will well over 100k miles? If so, how have they held up? I'd be curious to compare them with the high mileage 07-12s.
My target car is a 14-15 SWB RWD with about 85k.
