LED Emblem Wiring
Old Jul 19, 2023 | 09:17 PM
LexG's Avatar
LexG
Default LED Emblem Wiring
Wondering if anyone can help with wiring of an LED emblem. It came with a fuse tap with a red fuse at the end (assuming 10amp) and in inline 5amp fuse. I need an acc 12v switched fuse. What fuse should I pull from the fuse box in the engine compartment? Am I correct in saying that I would need to pull a 10amp fuse since the end fuse on the tap is a 10amp? Does it matter what way I plug in the fuse tap? Any help would be greatly appreciated.
Fuse Tap
Red Fuse, can’t see rating but assuming red is 10amp.
5amp in-line fuse for emblem circuit
Vague instructions.
Old Jul 20, 2023 | 07:28 AM
Gerf's Avatar
Gerf
Looks like it might fail at some point, is that fuse removable ?
Old Jul 20, 2023 | 08:44 AM
LexG's Avatar
LexG
@Gerf I attempted to pull it using a decent amount of force without trying to damage it and it won’t come out.
Old Jul 20, 2023 | 11:20 AM
Gerf's Avatar
Gerf
So then if the fuse ever blows you have to cut the end off and instal a proper fuse with wiring attached, might as well just do that before installation.
I would try to return that and get something that's serviceable.
What's the emblem?
Old Jul 20, 2023 | 02:28 PM
LexG's Avatar
LexG
What's the emblem?
https://floatingcentercaps.com/produ...-lexus-emblem/
Good point. I guess if for some reason it Does blow I can just buy a proper fuse tap and splice it to the emblem. Thanks for the input.
Old Jul 20, 2023 | 02:50 PM
Gerf's Avatar
Gerf
Sorry I didn't look at the pic very close, the end is just a connection and only looks like a fuse...the actual fuse is part way down the red wire.
You need an ignition on power source for what they show as a fuse box connection, I don't know if you're going to have a spare in your fuse box but you might.
I would just tap into an ignition on power source that meets your needs with a 3 way butt connector because the power source will already be fused and there is one on your emblem harness as well. Good luck.
Old Jul 20, 2023 | 03:17 PM
swfla's Avatar
swfla
Gerf has given great advice. The item may be low quality Chinese made. Hope it goes well for you.
Old Jul 21, 2023 | 07:11 AM
LexG's Avatar
LexG
Thanks for the help, and I am sure it is cheaply made. I will see how it holds ups…
Old Jul 28, 2023 | 10:53 AM
LexG's Avatar
LexG
Installed today.
File Type: mov
Old Jul 29, 2023 | 07:40 PM
dubsta1's Avatar
dubsta1
looks good
Snapkiller
May 25, 2019 06:49 AM
kurtismt19
May 18, 2019 06:45 PM
ivc
Aug 2, 2001 10:21 AM
